ESP disabled on my s550 need some advice
toyota sienna, S550, Subaru Outback
Question guys,
The ESP warning light came on and said that it's not working.
After restarting the car, it comes back on over and over again.
Decided to take it to the dealership.
Before going I will take off my staggered wheels and put my stocks back on because my car is a 4matic. The tpms sensors are on my 20 staggered setup. When I put my stocks on it will complain no wheels sensors and display an error on the dash.
Do do the wheel sensors on ESP have anything in common? I want to fix the esp as it's still under warranty but I don't want to ask the dealership anything as they may void my warranty due to my aftermarket staggered wheels.
Thanks guys..
Thanks guys..
2004 Ran SRT-10,2007 S550,2016 E400c
Well as you have been driving the car and the light just came on i would rule out the wheels and tires.. if the light came on right when you put the aftermarket wheels on then i would suspect them
Its a common problem front wheel speed sensors go bad there is a bulliten out on it.
depending on the year they will replace both front wheel speed sensors and a braket
What dealer?? with just wheels and links they wont work on the car?
to be safe i think it's still better idea to put stock wheels on. i don't see how tpms has effect on esp
but at the same time, i don't think your tire setup is a good combo for 4matic.
Once the car has the same diameter wheels (tyres actually), the owner can start looking after less sever issues.
You mean there is a technical bulletin for the W221? I'd be interested, I've never heard of the 221 having specific issues with ABS sensors. Can you post a copy or give a reference (if it is a US bulletin, I cannot get hold of it with the number).
I had the exact same problem awhile ago. But it wasn't caused by my wheel set up. It was a faulty sensor the dealer found and had to replace. They never said anything about my staggerd wheels causing the fault sensor?
thanks guys..i appreicate your response..wife took the car out yesterday and the car tranny got messed up...dealer said it's a axle issue...still in the shop..they said it's covered so I"m still waiting to hear back on final check out. Knock on wood..
i'm thinking of putting non staggered setup back on..but 20's ml63 amg style type.the same ones that ariel777 has on..
Thanks.
Thanks.
btw, the syptoms of the problem are put car in drive or reverse and it won't move!
car had to be towed...couldn't do much in terms of getting the car back at home to change the wheels as towing would only tow to mercedes dealer.
glad to hear it's all covered
staggered is no problem on 4matic, i have seen tons of staggered setup on awd cars. but you just need to be careful on tire size selection to make sure front and rear overall diameters being close to each other. the setup you have now the rear is quite a bit larger
Got the car back today. The front axle was cracked! Prior to being fully cracked it was causing metals chips to go into the bearings and caused the esp light to go on. This was the reason!
Warranty covered 100%. Phew!! Not sure what would cause this but glad it all worked out for me. Thanks guys.
There is 2 common esp/abr bulletins i will get the numbers on monday if you need them.. I never heard of us only bulletins.. Bullitens go off chassis numbers so they apply to all benz not one country
US bulletins seem to come from MBUSA and only cover cars for the US market. European bulletins of course are mostly the same by content but I believe in many cases MBUSA is more sensitive to release a bulletin. The numbering of the documents is different too, making it sometimes hard to find the equivalent Euro bulletin.
10 speed bicycle
If you would like to know about your question regarding a bulletin for wheel speed sensors, please PM me.
(1960) 300d, S550 AMG S500 S600 560SEL
jadeethan the staggered wheel can never give you problem it is the sensors, since your staggered wheels have the same diameter, what ever is the width (yours is 255 and 275) will never be an issue for all W221 series
not that it matters for him because it's been determined to be axle problem. but as i questioned, s63 and s65 both aren't awd. for awd, maintaining the diameters in the wheels is quite important. unless the same staggered setup is actually an option on w221 4matic
he has 255/35/20 and 275/35/20, the overall diameter of the rear wheel setup is more than 1/2" bigger than the front.
first three digit represent the width of the thread, the second set of number is the height of the tire wall and the last two digit is the size/diameter of the inner hole of the tire/mag-wheel size.
