DRL installation help
Old Jan 19, 2012 | 07:08 PM
Arlen777's Avatar
2002 Mercedes S 430(GONE), 2001 E320(GONE), 2007 S550(GONE), 2009 BMW X6(GONE), 2014 S550
I am trying to get as much info as possible on DRL installation, i ve read that you need 50w 6ohm resistor in order to connect them to Fog Lights switch, so here are my questions:
1. How many wires are inside when you splice the fog light wire and DRL wire, like 2-3? Just +/-?
2. Do i connect resistor to + only?
3. I couldnt find 6ohm one locally, but i found 7.5 ohm and 10ohm, if i put these will my DRL be brighter or darker?
Old Jan 19, 2012 | 08:59 PM
carboxy's Avatar
07' 911 Turbo, 09 ML63
i love your quad exhausts.. is that aftermarket? or oem add on
Old Jan 19, 2012 | 09:05 PM
rominl's Avatar
16 GL550
i really highly recommend against using resistors. they get pretty darn hot, not safe
Old Jan 19, 2012 | 10:03 PM
Arlen777's Avatar
Thanks yes they are aftermarket ones from ebay
Old Jan 19, 2012 | 10:04 PM
Arlen777's Avatar
So how would i go about installing them without resistors?
Old Jan 20, 2012 | 12:27 AM
rominl's Avatar
16 GL550
do you want them to be on only with fogs?
if you just want it to be on with headlights, you can wire them to the bumper reflector. a member did that and no need to put resistors.
Old Jan 20, 2012 | 01:00 AM
jadeethan's Avatar
toyota sienna, S550, Subaru Outback
are you talking about rudypartsworld who made that comment? If so i had contacted him and he said that they still act erratic. I am suppose to get some more information on a direct wire without issues. I'll keep you posted.
I'm suppose to do the s63 kit as well but the drl seems to be the only obstacle so i'm on the same boat and trying to get all info before I dive into the conversion.
Old Jan 20, 2012 | 02:55 AM
rominl's Avatar
16 GL550
i forgot the username but he had a thread in this forum about doing the conversion himself. did he say what his problem is with the reflector bulb? the LED goes out after a while?
Old Jan 20, 2012 | 05:20 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Well you got my PM already on this...Should be enough.
Old Jan 20, 2012 | 07:47 AM
carboxy's Avatar
wow. looks great. can you send closer pics on back n rear view.. i seen it on before but yours look better..
where can i get lights and amg kits
what do you recommend
Old Jan 20, 2012 | 07:49 AM
carboxy's Avatar
Old Jan 20, 2012 | 09:19 PM
Arlen777's Avatar
Yes i want to connect them to fogs, you know how?
Old Jan 20, 2012 | 09:22 PM
Arlen777's Avatar
I will take some pics for you tomorrow, i got everything original from ebay, but someone on this forum got replicas and it fits perfect too, so it depends on how much u want to spend.
Old Jan 21, 2012 | 03:04 PM
Arlen777's Avatar
So?? Nobody has an answer??
