Old Jun 16, 2015, 01:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
Print Wikipost
Comfort and Sport mode
Old Jul 25, 2016 | 11:57 PM
  #51
Nuru's Avatar
S350 BT 4MATIC
Originally Posted by lwain56
The "S" button makes the diesel S350 an animal!
Hmmm, an oil burning animal, huh, that makes me want to try it out even more now - Thanks.
Old Oct 20, 2017 | 10:34 PM
  #52
Victorpb62's Avatar
2004 e500 Mercedes
Comfort and sport mode
I have a 2004 e500 Mercedes when I'm in comfort mode at a dead stop when i accelerate the car is not responding in sport mode it is does anyone know what the problem is
Old Feb 24, 2019 | 08:18 AM
  #53
Avatar2014's Avatar
2008 E63 AMG
Airmatic/ADS Sport 1 and Sport 2 Question from DustinN
Originally Posted by dustinN
For the '07 E63 AMG, can you tell the differences between S mode, Sport 1 and Sport 2 mode? I use S mode for daily driving but I am not sure when to use Sport 1 or Sport 2. Thanks.
I have the same question as does DustinN. Does anybody know.
Old Feb 25, 2019 | 09:19 AM
  #54
dustinN's Avatar
09E350, 07E63, 13CLS63
For DD, I use Sport mode for transmission, I have better respond when I need to accelerate and it starts at 1st gear and holds the gear longer. C starts at 2nd gear. For the suspension, when you are ready to have some action, try S2, it lowers the car another 1/4 inch, the suspension is a lot more firm, at high speed/quick stop/at the ramp... you feel like the car stick to the road and don't have the body rock rolling. To me S1 is just half way between S & S2 :-) I have worst mileage and tires wear for S2.
Old Mar 26, 2021 | 08:25 AM
  #55
MBRiposte's Avatar
2017 GLC 300 W4 & 2018 C43 AMG W4
Apparently, you can change steering and stay in comfort. Info starts 13 mins. in:
https://mbzmaster.com/boost-mercedes...sive-tutorial/
Excellent collection of videos at MBZ Master.
Old Mar 1, 2022 | 03:18 PM
  #56
Numair Aidroos's Avatar
EQC, S Class Extended, Grace CVT.
Originally Posted by Quadcammer
oh for gods sake. you act like this thing is dangerous on the highway in comfort mode. Its not even close. Is it a bit more bouncy, of course, but most people aren't doing 125mph around sweepers on the way to work. If you want to drive aggressively, use the bloody sport mode, if you are driving normally, comfort is fine.
You shouldn't. Its MB's attorneys writing the manual on the absolutely miniscule chance that this change from c>s will result in loss of vehicle control. Its bull****.
Switch it whenever the hell you want.
I Have been switching transmission modes from s/m and C on the go for the past 8 years. But my question is how does manual mode work? As far as I've notices it holds speed shifts longer. Sometimes on the bends I accidently switch to manual mode and gun it. When I realise the wheel spin and tail slip, I know I'm not in sport, but manual mode. Does this over revving damage the ZF transmission?
Old Mar 1, 2022 | 03:21 PM
  #57
Originally Posted by GPrime2
There's something here that I haven't seen mentioned so I'll chime in with it. You can basically use sport mode to set your "wild driving" throttle and transmission adaptation settings, and comfort for your normal ones, if you're going to be driving the car hard at all. If you do the adaptation reset procedure (key on, hold accel for 5 seconds, key off while still holding accel, remove foot from accel, wait 2min, start car) then you'll get about 40-50 shifts in each mode for the car to learn how you drive in that mode.
I've done that with mine and in comfort I have to beg her to go above 2500 RPM, in sport mode she hangs around 4-5k when I let off just waiting for the throttle. I'm not sure why everyone seems to think these things are limited to being boring highway cruisers, they're absolute animals on the road, especially considering their weight.
Does taking fast corners in manual mode and holding gears, like just the 3rd speed level and flooring it burn the transmission?
Old Mar 2, 2022 | 01:53 PM
  #58
BOTUS's Avatar
S500
did u ever notice the buttons on the back of the steering wheel?
the gearboxes fall to bits, it how they designed it, not how you drive - fluid change every 37k miles help a little
Old Mar 2, 2022 | 02:01 PM
  #59
In 10 years, I only used the manual mode twice. Other times I switched to it by accident instead of sports from comfort. Will this gear over revving on ocassion cause long term conductor plate or other part damage?
Old Mar 2, 2022 | 03:14 PM
  #60
BOTUS's Avatar
S500
the gearboxes are quite fragile and a few very common issues come to the surface on all other them
conductor plate speed signal sensors die - it just happens, the way you drive can't influence
torque convertor lock up clutch gives up - it just happens, the way you drive can't influence
ISM change selector on the outside of the gearbox gives up - it just happens, the way you drive can't influence - but the more miles / on off cycles the car has, the more likely you trip the designed in software fun !!!
change solenoids clog up and cause the clutches to wear out - this is in-acted by driving style / abuse
not changing the fluid and filter leads to increased wear and possible actuator / O ring damage - this is in-acted by your maint programme
the more gear changes you instigate and the harder you work the car, the more wear and tear the car takes - a choice of how you spend your money / waste the planets resources
if its a V12 and you use the throttle pedal you need a rebuild every 20k miles - this is in-acted by your purchase choice
Old Mar 2, 2022 | 11:09 PM
  #61
Thank you botus. So the 7g plus is a fragile box?
Old Mar 3, 2022 | 01:51 PM
  #62
BOTUS's Avatar
S500
I would describe it as one of the worse auto boxes ever created in a rear drive car - of course front drive autos used to be spectacularly worse (but you should expect that)
Old Mar 4, 2022 | 01:12 AM
  #63
Thanks again. I put the transmission in Manual mode to realise, it up shifts and down shifts when necessary, if we fail to use the paddle shifter after 3500 rpm for up shifts, and upon braking the w221 down shifts accurately. Frequent servicing and careful maintenance is the only key for this transmission I suppose with a conductor plate as a back-up spare part.
Old Mar 4, 2022 | 08:39 PM
  #64
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
It depends on the year. by the facelift year of 2010, all of the bugs were ironed out of the W221.
Old Mar 5, 2022 | 12:15 AM
  #65
2010, non facelift.
Old Mar 5, 2022 | 04:44 PM
  #66
lkchris's Avatar
'10 CL550, '12 GL550
What a silly thread!
The original post is written so unclearly as to provide no clue what the author is questioning.
some interpret it to reference the suspension system.
others interpret it to reference the transmission.
the two are NOT connected in any manner and are separately controlled.
on the 4Matic W221 you have two possibilities …
1. You can select soft or firm shock absorber action.
2. You can select economy or performance transmission operation.
You have 4 possible configurations … have fun. Read your owners manual when you have time.
Old Mar 6, 2022 | 06:56 AM
  #67
BOTUS's Avatar
S500
this thread took on a new lease of life this month - 1 March 2022, expecting a non native English speaker to consruct the perfect sentence, with perfect grammar, about a topic they are unsure of, its a stupid way to think
the suspension and gearbox settings ARE connected - the suspension, gear change points and distronic plus cruise, are all interlinked with the three crazy modes - where you have the option to go from very average, worse or more muddled
re-reading the post 1 March, Numair - have you considered when driving like a maniac, the lumbering beast morphs into lunatic mode. Where the car gets very unruly, as you fight electronic interference, its inadequate suspension control, considerable weight and physics trying to kill you - it can mean your steering inputs need to be extremely rapid and then constantly corrected to combat the electronics fighting you - add in the fact your are being thrown around the car like there's a hurricane going on - this can lead to the driver executing an unintended gear change by accidentally operating the buttons on the back of the steering wheel - this often makes things even better.
I have noticed mine refusing to change gear a number of times - and with v8 smooth enough under wild bumpy road driving conditions, you can either be revving its nuts off or even hitting the rev limiter without noticing. Not forgetting if you used full throttle for more than a split second the car starts "helping" by instantly transforming your effective throttle control / power output by dropping you down two ratios below the one you needed. Hence as I point out above, it turns itself in to a lunatic beast. I often felt this complete refusal to change up was just a normal Mercedes glitch - but reflecting on the three times I remember its happened, it was often just after significant steering inputs had been made - So was it driver instigated - or a loss of control as the signals get interference due to the speed the driver moved the wheel ? I've always found it got over itself by using the right wheel button to push it back to D.
Old Mar 9, 2022 | 09:16 AM
  #68
Thanks again botus. The check engine light was lit on this afternoon, so I went to MB for a quick scan. The front sam communication error was listed. I was advised to leave the sedan until next week or drop it off on Monday morning. No physical inspection was carried. I called an indie, they said they would drop by the next morning. Where may I locate this SAM unit, and what all do I need to get checked in terms of wires, relays, and fuses?
Seems this explains the erratic transmission behaviour and perhaps any future issues.
All I did prior was a high pressure air cleaning of trh engine bay and a full service B.
Old Mar 9, 2022 | 04:46 PM
  #69
BOTUS's Avatar
S500
engine light isn't the front SAM
if its a tractor could be lots of stuff
exhaust back pressure sensor 50 bucks DIY in 5 mins from above 24mm deep socket required (often see as ambient pressure reading off whack even with engine turned off - in live data 5000kpa or something is wrong) dealer has the bits in stock
boost hose popped
turbo actuator stopped moving either gummed up, or a wire fell off the circuit board (usual merc trick), key on bonnet open, start the car blip the throttle the arm should dance about
or a fuse popped stopping turbo actuator - because another designed in failure on swirl flaps has gummed up secondary inlet ports and jammed the swirl flap drive motor (called inlet port shut off motor I forget in Merc world ) you can fix this with a small resistor on the middle 2 pins of the drive motor the car won't know any different
EGR gummed up and given up -stupid money and can be nightmare to get off
Front SAM might have had a bath that's a usual Merc trick too - not such a clever idea on a 221 though !!! ebay if it has BUT get the right part numbers
the FRONT SAM quite likely said software out off date - reflash - thats normal - then it'll say the rear is out of date next time - u can ignore both
as for a list of errors they store everything about everything - usually load of old rubbish / lies
Old Mar 9, 2022 | 11:27 PM
  #70
boost hose popped
Thanks as usual Botus. You are the best, God willing.
Symptoms are such, car would hesitate to start since all of 2021, it was diagnosed as a bad glow plug sensor, and replaced. In 2022, it starts in 1 fire, but ever since this check engine light, the car drives more powerful and mpg went from 8.8L/100 km to 15.6L/100 km. Apart from that Turbo steel pipe, don't know what it's called has some noise. Told these symptoms to MB, they could not understand. Once yesterday I floored the car, and it hesistated at 2500 to 3000 RPM, it was fluctuating in between and not upshifting. Strange, though my foot was floored on the accelerator. Finally I let go of the accelerator and tapped it again, that sorted it out.
Apart from an air cleaning the engine bay had nothing. Horns we're changed via the fender lining, lots of wires inbetween to get messed, brake oil flushed, new boys changed the air filters (do not know if they accidentally cut some wires in the air element removal or installation).
Old Mar 10, 2022 | 01:27 PM
  #71
BOTUS's Avatar
S500
the control module is a service part - with a later brain to suit later glow plugs
replace 6 plugs and the control box (usually called a relay (its got software so its not really a relay) every 60k miles
ALWAYS have engine very hot before trying to get the plugs out (use "PLUS GAS" as release agent for a few days before trying and ALWAYS use a torque wrench set low to undo then - they love to snap - if they do, don't panic come to your house specialists for not much money out there
never use genuine Merc parts they are made by Beru and you can get the very same thing for 1/3 of the price
They have a VGT turbo rather than a conventional wastegate - the inlet of exhaust gases to the turbo vanes varies (that's the V of variable geometry turbo VTG) this is the little arm reaching to the turbo - if this isn't wobbling as you blip the throttle - it will make little power - it will be very slow and only make boost at high revs, if you go hunting for the boost it'll then make the EML come on and it will go in limp mode. The Exhaust back pressure sensor - always fails at 100k mile 10 year mark - its another another stupid name by Merc - its really the VGT boost pressure sensor - and sends the info so the turbo actuator knows where to place the turbo geometry to increase low end boost or stall the wheel to reduce high rev boost
you need to plug in to decent diagnostics they are VERY basic - its just a tractor after all
Old Mar 10, 2022 | 11:44 PM
  #72
Indeed. Thanks again Sir Botus.
But why would the scanner read only short circuit on front sam? And not point to any other listed issue now?
Old Mar 11, 2022 | 12:53 PM
  #73
BOTUS's Avatar
S500
the limp mode can be harder to trigger than you might think - if the light comes son and stays on after a few key on off cycles - then you should be able to see fault codes
inconsistent boost pressure can lead to intermittent EML and strange performance issues - can you hear odd sounds when on off the throttle - wooshes or shrieks ?
Old Mar 11, 2022 | 01:08 PM
  #74
Nothing what so ever. Star scan pointed to a short circuit on the Front SAM. No water has been exposed to it in 10 years. Only air washed, high pressure air cleaning. Only thing done was air filter replacement, after which the light came on. Any wires around the filter housing that might be hidden under the filter cases? That is the only place where I haven't checked. Any sensors under the filter cases on left or right side?
Old Mar 12, 2022 | 02:29 PM
  #75
BOTUS's Avatar
S500
some markets get extra garbage for goodness knows what on various part of the emission systems
the w221 should have a DPF and they give all sort of fun when its going wrong / not regenerating correctly
Engine breather was a bad design and that plays up, there was a modified part with red seals (but shouldn't give silly issues)
Fuel filter needs regular changes, some have a sensor in them that costs much more - forget for what - water detection and or heater? (its sits above that useless swirl flap drive motor in the middle of the V
