Car is low
Old Mar 16, 2012 | 12:10 AM
Beauty500B's Avatar
S500
Car is low
Hello:
Suddently message pops up and says "Stop your car is low" . Can some one help me in diagnosisng it. Many thanks
Old Mar 16, 2012 | 12:20 AM
Beauty500B's Avatar
S500
It says : "Airmatic, Stop your car is low "
Old Mar 16, 2012 | 06:30 AM
rene_gts's Avatar
From manual.
STOP Car Too Low:
You have started driving although the vehicle level was too low.
The vehicle will be raised.
Stop the vehicle as soon as it is safe to do so.
Engage the electronic parking brake.
Wait until the message disappears from the multifunction
display. You may then drive off.
STOP Car Too Low:
The AIRMATIC is malfunctioning.
Avoid excessive steering maneuvers. The fenders or tires could otherwise be damaged. Listen for scraping noises.
Stop and press the vehicle level control switch to select a higher vehicle level (Y page 343).
Do not drive faster than 50 mph (80 km/h). X Contact an authorized Mercedes-Benz Center as soon as
possible. There is otherwise danger of an accident.
Old Mar 16, 2012 | 08:44 AM
IDriveAnM5's Avatar
'10 S550 4Matic, '06 BMW M5
I had this same message in my 2004 S500. I came back from vacation and the front end looked like it was sitting on the garage floor.
In my case, the dealer diagnosed a leaking AIRMATIC element in the right-front wheel assembly and replaced it.
You might have a leak in an AIRMATIC component somewhere, causing the air to escape from the system even after the AIRMATIC pump engages.
Good luck.
Old Mar 16, 2012 | 10:51 AM
Beauty500B's Avatar
S500
Many thanks for the response. I will take it to MBZ dealer. By the way where can I buy reasonably priced Shocks for S500
Old Mar 16, 2012 | 02:09 PM
Tobby's Avatar
2020 AMG C63S Coupe, Kawasaki ZX10R
Arnott Industries: http://www.arnottindustries.com/part...18_pid169.html
Old Mar 16, 2012 | 04:29 PM
Diesel Benz's Avatar
Originally Posted by Tobby
They say "coming soon".
Old Mar 17, 2012 | 09:33 PM
Beauty500B's Avatar
S500
Is there a simple method/test to check the leak in an AIRMATIC component
Old Mar 26, 2012 | 04:45 PM
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
did you try to press the raise car button? it is located on the center left monitor screen
