Changing tire size
Old Mar 31, 2012 | 09:40 AM
Mehdi Rahimi's Avatar
S350 L
Changing tire size
HI, I drive S350L with AMG body kit (2009). I already experienced my first burst with the michelin pilot sport, 255/35/20 series tires up front. Thinking of replacing with a 245/40/20 to avoid repeat offense. Anyone tried this combo? If so, any potential issues? Will keep standard 285/35/20 series in back.
thanks
Old Mar 31, 2012 | 05:13 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
thanks
the middle number on the tire is the height of the tire, so 40 in the front and 35 in the back wont work. u will also have to change the rear with 40.
Old Apr 6, 2012 | 03:53 AM
T0ked's Avatar
2007 S550 Sport
Actually, the middle number represents the height of the sidewall as a percentage of the tread. So on a 245/40R20 the tread width is 245mm, the sidewall is 40% of 245mm, and the rim is 20". So wider the tread, the lower the middle number should be to keep the same overall diameter.
The 245/40R20 is actually more similar in diameter to the 285/35R20 tires in the rear than the original 255/35R20. So it should work while giving you a little more sidewall without adversely affecting ABS and speed sensors.
Old Apr 11, 2012 | 12:13 PM
marthyh's Avatar
S500
Maybe this helps:
http://www.tiresizecalculator.info/
Old Apr 13, 2012 | 03:33 PM
S350 L
Thanks guys
actually I made a Mistake the rear tire size is 285/30/20 and front size is 255/35/20 I thinking to change the front size with 245/40/20.is it possible?
