Excessive fan noise from seats ?
Old May 27, 2012 | 10:11 AM
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
Have you guys noticed whenever the ventilated seat fans speed is set to maximum (3 leds on)... it is on the noisy side? I have tried it on the passenger side as well and the noise from the fans are the same.
With the radio off...you can really hear the fans.
Is that the design or just my car?
thanks.
Old May 27, 2012 | 10:53 AM
Quadcammer's Avatar
96 and 08 911 turbos
mine is just a 220 but I don't really hear the fans.
Old May 27, 2012 | 12:27 PM
I would think that is the way it should be.
Unless the fans are more powerful than the 220 version...but still, I would think one should not be able to hear it from the seats. Unless the radio is on, it is sort of annoying and the noise level goes up or down according to the speed I set (1-3 leds).
Old May 27, 2012 | 07:26 PM
thekkdude's Avatar
2010 S550
try pumping up the side cushions a little. This made my noise go away.
Old May 27, 2012 | 07:32 PM
marthyh's Avatar
S500
Not louder then my engine noise hehe ,I can hear the difference between 3 blue lights and 2 or 1 ,but its a faint background noise ,but audible indeed with engine idle and radio off.
Old May 27, 2012 | 09:24 PM
I will certainly try that. Thanks for the tip.
Old May 27, 2012 | 09:27 PM
At first I thought the noise was from the engine compartment...which I was concerned at first.
At least I know you guys are hearing it as well...so it is nature of the beast.
I will try adjusting the side bolsters like the other member mentioned to see if it helps.
