Ignition Key Switch Cover (Escutcheon) Replacement
I cannot speak for yours or others (disclaimer?), but using thumb and index finger and pulling straight out, I can pull the "cover"/escutcheon out of the female key slot. I then can insert the physical key to start the car.
My experience is it can simply be removed and replaced w/ a new one. Getting a new one should be fairly straight up. Sorry I cannot help w/ MB part number.
Good luck.
I've already ordered the escutcheon from the dealer, when I see the part hopefully it's pretty straightforward in figuring out how to replace the current piece. I really hope the escutcheon snaps in from the front and isn't directly hooked to the ignition switch, which would probably require removal of the dash panel.
