2007 S550 Hazard Lights
Old Aug 4, 2012 | 08:42 PM
rkcarson's Avatar
2007 S550
Last night the hazard lights were flashing. I tried the locking/unlocking, starting, etc and could not get them to stop flashing. Finally removed the consumer (rear) battery and the starter (front) battery to get them to quit. Waited for 30 minutes or so, then connected the batteries up again. They started flashing again. The red triangle button is also on. Does anyone know why this happens and what I can do about it? I do not have a fuse chart (some liked the tool kit more than I did) so I do not know what fuse I can pull so I can at least drive it to a dealer.
Appreciate any help here.
Old May 8, 2013 | 07:12 PM
hotcorner216's Avatar
2008 C350 Benz, GLA250 4matic
How do we remove/replace the hazard lights? is there a flasher? if so where?
Old May 16, 2013 | 08:58 AM
tixe31's Avatar
S550 Mercedes Benz
Be careful removing the bulbs I removed the high beam bulb in my S550 to get a bug out of the headlight and the bumper had to be dropped and the headlight removed just to put the high beam bulb back into place and it easily twisted out however would not twist lock back into place so $250 later my bulb was back in place........bad design on the bulb replacement
