Split View monitor
Old Aug 7, 2012 | 05:32 PM
novots's Avatar
2006 E-500 4matic
Split View monitor
It's been a long time since I've been on so if this question has come up I apologize, still trying to navigate my way around.
Anyway I recently purchased a 2008 S550 4Matic. This question may be very stupid but does anyone know if the split view monitor can be installed on the 2008. Not sure if it's compatible since I thought this came out in 2009/2010
thanks so much
Old Aug 8, 2012 | 03:29 AM
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Not possible unless you swap the comand unit and all the cables as well. BIG job.
Old Aug 8, 2012 | 11:01 AM
novots's Avatar
2006 E-500 4matic
thanks so much Chris! guess it's not worth it since I'm assuming the advatage to this is primarily for the passenger correct??
Old Aug 8, 2012 | 11:14 AM
There is alot of upgrades more than splitscreen but yes that is just for the passenger.
Old Aug 8, 2012 | 11:25 AM
novots's Avatar
2006 E-500 4matic
Thankss again Chris, one last question and maybe this is out of your area, but if I wanted to install a dual rear entertainment system with just your basic DVD function, is that hard to retrofit if I wanted them to somehow be built into the back of the headrests?
Old Aug 8, 2012 | 11:32 AM
A bit hard if you have neck-pro...And little space.
