WTB: Rotors and Pads
Old Nov 12, 2012 | 11:00 PM
ronin1099's Avatar
S550
Would you recommend going with stock pads and rotors or with aftermarket? If yes, what company?
Is anyone here selling S550 OEM rotors and pads? Preferably new or like new.
Old Nov 13, 2012 | 12:06 PM
Wolfman's Avatar
Super Moderator
Stock pads are terrible IMO. I switched to Akebono ceramic performance pads and they are fantastic! No brake dust even after a week or more of driving and the rotors are smooth like a mirror. Even on the SL which as 8 piston calipers.
Wheels now stay cleaner than the car
Stopping power appears to be the same as stock.
Re. the rotors, I have used MB stock rotors (which are quite cheap or Brembo's)
Old Nov 13, 2012 | 03:07 PM
Em Bee Lover's Avatar
CL550 1976 450 SL
I have garden variety, 2007 4-Matic. I, too, tired of my non-stock chrome wheels getting caked w/ brake dust. I went w/ Akebono ceramic, as well. Wheel dust/residue was really, really reduced. Not a cowboy driver, I found zero change going to ceramic.
Rotors....I researched and found dollar/quality, imo, the coated Zimmerman rotors were first choice.
Out of warranty, my indi mechanic said just go buy what you want, he simply charged for installation.
Good luck.
Old Nov 13, 2012 | 04:11 PM
ronin1099's Avatar
S550
Thank you for you suggestions. Brake dust on stock pads is pretty bad. I will look into Akebono ceramic performance pads.
Good luck.
Zimmerman rotors do they perform as well as stock? are they much more expensive?
Old Nov 13, 2012 | 04:37 PM
PelicanParts.com's Avatar
SPONSOR
+1 For Akebono Ceramic brake pads and Zimmermann Coat Z rotors, which perform just as well, if not better than the OEM rotors. Pricewise, the Zimmermann rotors are cheaper than OEM.
Old Nov 13, 2012 | 05:17 PM
ronin1099's Avatar
S550
how about noise? some people claim much more noise.
Old Nov 14, 2012 | 11:30 PM
CL550 1976 450 SL
Zim rotors and ceramic Akebono's haven't a discernable increase in "shriek, screeech or noise pitch", imo. 'Course, I am old and hearing is kaput...j.
Really, I like my combo. Biased, but I researched like hell. Others, I am sure, are equal, worse or better. But, I am happy.
Good luck.
Old Nov 15, 2012 | 06:50 PM
gzus's Avatar
s550
i got oem s63 rotors and calipers for all 4 wheels with spindel message me if your intrested or email me for faster responce ill rather you email me GZUSTL@gmail.com
Old Nov 19, 2012 | 09:25 PM
about6's Avatar
S600
+1 for Akebono's use this on all my vehicles!
Old Nov 21, 2012 | 05:05 PM
SPONSOR
As Em Bee Lover noted, no noise noted with the combination mentioned above.
Old Nov 21, 2012 | 11:20 PM
malahhaor's Avatar
06 Carrera4
looks like i'll have to do my front rotors and pads in the spring. I have also been thinking if i should go with Akebono's or do an upgrade.
from what i've been able to learn, e55 front rotors and calipers should bolt on, in the back euro s600, unfortunately not available in US. anyone knows any other combos that may bolt on as well?
thanks
Old Dec 7, 2012 | 02:33 PM
SPONSOR
FYI
I agree with the combination suggested + a bit of needed safety inspection/maintenance.
Excess brake dust on front wheels may indicate one or more of the REAR caliper pistons are seized in the caliper bore.
Any excess resistance pressing the caliper piston into the bore is a symptom of brake issues.
Odd wear of brake pads = a single or pair of pads thicker/thinner than others on the car.
Black brake fluid, could be maintenance or cooked fluid from a dragging caliper.
Difficulty bleeding, could be bad master cylinder, hoses, and/or calipers.
Visual inspection of brake hoses is 99% useless.
http://www.peachparts.com/shopforum/...1999-c280.html
The issue is INTERNAL hose lining...
FYI: Stainless braided brake hoses are pretty, but have the same basic life cycle as stock.
Brake:
Some Facts About Brake Hoses:
#1. The industry standard average safety life of a brake hose is six years. FYI data SAE: J1401, J1703, J1705, J1873, J1406, J1288, J1403, J1833, J1402.
#2. Brake hoses deteriorate from the inside as well as the outside.
#3. Moisture is absorbed into brake fluid systems through brake hoses.
#4. Contaminants in brake fluid act abrasively on the inner wall of brake hoses.
#5. The brake hose reinforcing fabric deteriorates through expansion and moisture.
#6. High operating temperatures contribute to the deterioration of hoses.
#7. Brake hoses swell with age and restrict flow.
#8. Generally all brake hoses on a vehicle deteriorate at the same rate, So all hoses should be replaced if one is found to be faulty!
Brake hose failure mode:
#A. Rupture (burst hose) = age, exercise (too many miles) or impact are the typical cause.
*B. Partial internal collapse = the inner ply becomes damaged/detached acting as a partial restriction and/or one way valve.
#C. Full internal Blockage = the inner ply becomes damaged/detached acting as a plug = brake pedal still feels good but there is no brake application.
http://www.peachparts.com/shopforum/...411-brake.html
roy@pelicanparts.com
