No power to Rear cigarette lighter, but fuse Is good
Old Dec 4, 2012 | 02:28 AM
Zerocarpileup's Avatar
2008 S63
Can't figure it out. No power to cigarette lighter or rear 117 15a fuse. Fuse is in good shape. Tried new fuse, same thing. Is there another fuse up front or on the sides that might be out that is affecting this one?
Old Dec 4, 2012 | 05:59 PM
2008 S63
Any ideas?
Old Dec 4, 2012 | 06:21 PM
nauticalx's Avatar
no idea but I would start pulling each fuse one by one and checking them to see if one doesn't check out
Old Dec 4, 2012 | 09:19 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
Does your car have any aftermarket audio or radar equipment installed? I had no power on my rear outlets and when we got into it, realized either the audio or radar equipment was wired incorrectly off my cigarette power line.
Did it just start happening/ is it a used car? etc.
Old Dec 4, 2012 | 09:24 PM
2008 S63
Well yes.I was using the cig light for amp turn on wire. All wired and fused correctly. Can't imagine what kind of damage occured if any. So how was it "wired incorrectly" and what did you end up doing to resolve this.
Old Dec 5, 2012 | 03:05 PM
2008 S63
Could there be a relay associated with this fuse?
Old Dec 5, 2012 | 04:40 PM
I don't know. The tech found the wire was teed off somehow and he rewired it for me. Don't think there was any issue with the fuse.
Old Dec 5, 2012 | 06:42 PM
platt-deutsch's Avatar
2019 S450
It may be the cig lighter unit itself. Some have a fuse link in them. Take a voltmeter or test light and see if there is power on the fuse itself. There is a small spot on each side on the top of the fuse that you can touch a test light to. Hope that helps..
Old Dec 5, 2012 | 08:02 PM
2008 S63
I'm getting no voltage from the fuse nor the inside of the fuse mounting location. A fusible link you say. I wonder where in line that thing would be.
Old Dec 16, 2013 | 06:17 PM
davetfft's Avatar
2009 S550 4Matic P03 Blk/Blk
Question any fix?
I have the exact same problem. no aftermarket anything....
2009 W221
Dave
Old Dec 17, 2013 | 09:18 AM
mirage1's Avatar
S350 2012 w221 -E350 W212
2009 W221
Dave
I have had this problem for three years now....
Old Dec 17, 2013 | 09:26 AM
davetfft's Avatar
strange... there doesn't appear to be anything wrong, good ground too
Old Dec 17, 2013 | 12:45 PM
konigstiger's Avatar
'71 Pinto
Check R relay
Attached Thumbnails No power to Rear cigarette lighter, but fuse Is good-relay.jpg
Old Dec 17, 2013 | 01:21 PM
davetfft's Avatar
I'll check!
Old Jan 1, 2014 | 10:37 PM
baltos550's Avatar
s550 2009
a simple fix
This happened to me. On the driver's door, check one of the buttons called the override switch, which disables certain functions in the back seat. Press it and you should be good to go.
Old Jan 2, 2014 | 09:22 AM
davetfft's Avatar
it's worth a try!
Old Jan 2, 2014 | 11:32 AM
'71 Pinto
If override switch is activated indicator lamp should be on.
Old Apr 7, 2015 | 05:24 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I know, very old thread, but any resolution?
Just bought a used S class with this issue. Lighter inop, as well as analog clock and driver's side dynamic seat. Yes, fuse #43 is good. Frustrating.
Old Apr 7, 2015 | 05:30 PM
2008 S63
Might have not noticed yet but does your headlight switch work? How about the buttons next to the command screen? You might need to change out the clock. The clock seemed to be the problem for me. Switched it out and it solved every issue.
Old May 13, 2021 | 11:18 PM
Juan Moreno's Avatar
W204
Location
where is this switch located exactly or near by ?
Old Oct 12, 2021 | 11:13 AM
Maxvel_ua's Avatar
2009 Mercedes Benz s550
If I am not too late.
Override switch is located on a Driver Door - where you have your windows controls.
It would be located closer to your elbow, further from palm, when you rest your arm on a door handle.
Old Oct 12, 2021 | 08:33 PM
augemini1980's Avatar
2004 Mercedes w211 e320 WAGON Green 74000 miles
I just fixed mine it's a relay you get to through the back seat arm rest. Its this one ill post a picture. However be warned I changed my now and about a week later I was driving around and my car went into some mode where I couldn't change gears I couldn't put neutral I was stuck in the middle of an intersection for 7 hours now my key doesn't register to my car I don't know what the **** is goin on
Old Oct 12, 2021 | 08:42 PM
Maxvel_ua's Avatar
limp mode maybe?
Old Nov 3, 2023 | 10:32 PM
luisalvarezz22's Avatar
2007 Mercedes S550 RWD
This worked for me lol
After years of putting up with this problem this solved it lol I checked fused swapped relays checked the real cig lighter wiring and all it took was me turning off the rear window lock on the driver door arm rest lol I had it off because my husky who usually resided in the back seat is a master escape artist hahaah oh how I miss these forums God bless you all.
Old Mar 24, 2026 | 02:28 PM
Mkirby1986's Avatar
'01 Mercedes C240 w203, '01 Pontiac GTP supercharged 3.8, '87 Z31 Nissan 300ZX, '02 VW Cabrio
I'm having the same issue. Acquired my C230 w203 this last December and the cig lighter in console hasnt worked. Keeps blowing fuses, even with the cig lighter disconnected and removed it still blows fuses instantly. Wiring looks flawless.
Anyone solved this yet?
