When ordering brakes do I need to order the sensors too?
But, as said, they are reasonably cheap (about the only thing mechanical on these beasts that is) and when apart, why not do it? Just my opinion.
For what it's worth....I did Zimmermann rotors on front and Akebono pads. Great dust reduction compared to oem's. Can't sense any stopping performance change.
While this thread is open...i'm looking for rotors that don't rust in the middle part that have some coating... I hate it when the rotors on that part rust (not the contact surface where the pad meets the rotor). Can you advise or the r1's and/or the zimmerman rotors are coated and last?
Thanks!
The old sensor looks exactly like the new sensor, no wear on it. So....
Did I do this correctly? Maybe the rear pad sensor is keeping the message on?
I should have just paid the $300 and been through with it.
Thank for an help in advance.
Drew
2008 C300
Thanks!
Rusting middles. I have six months on Zimmermann coated. Driven in Wisconsin snow and salt. Middles are as grey as original; no rust. So far, at least.
DREWSCUE--sensors. Was the code showing and then pads were replaced? Did your independent reset the computer to clear the sensor fault? To my experience, just replacing a part won't dump the fault code. If the fault code wasn't showing on your panel, I would check their connection. Just a thought and possibility, as to why it's still there after you put new ones in.
Good luck.
I get messages in the middle of my speedometer cluster saying A3 due, taillights out, etc. One of the messages is check brake pad wear and it was on before the pads were replaced. I saw where you could reset for A/B service, etc on another thread (by pressing different buttons on steering wheel), but not brake pad message. Thought it could only be reset by replacing the sensor, even by my independent.
A generic question, does a new sensor look any different from an old sensor? Mine looked exactly alike. The one I replaced went in the middle of pads in an opposite direction, so I don't see how the sensor could wear down with the pads. Or does it even wear down? I'll check the connections and repost on C class thread unless I resolve here.
Thanks for your time!
Okay, problem solved......thanx again!
