Keyless Go Key 2007 S550
Old Mar 29, 2013 | 06:37 PM
PNigel's Avatar
2007 S550
Went through a security checkpoint and my key went through a X-Ray Machine. When I returned to my car, the keyless go would not work. Looked in the manual and to my horror, I discovered that the key should not have been exposed to the radiation. Can the key be reprogrammed?
Old Mar 29, 2013 | 08:12 PM
TDwayne69's Avatar
2012 CLS63 PP
That seems strange, because I've sent my key through the x-ray many times and I've never had an issue. You may want to check the battery in the key fob.
Old Mar 29, 2013 | 08:20 PM
Yidney's Avatar
2008 CLK550 Cab
Mine has been through airport security probably 100 times. That isn't your issue. Every now and them my keyless go doesn't work but using the button on the remote seems to reset it.
Old Mar 29, 2013 | 10:44 PM
PNigel's Avatar
2007 S550
Thanks a lot TDwayne69 and Yidney. I will check the battery and try to reset the key again. Hopefully I do not get the "Key Not Recognized" message again.
Old Mar 31, 2013 | 09:57 AM
new550's Avatar
2015 s550v4
After replacing key's battery, remove the "push to start" button and put the key in the slot to start manually, turn off...then replace button...all will be well again.
Old Apr 5, 2013 | 06:46 PM
PNigel's Avatar
2007 S550
I replaced the battery, removed the button, started the car, turned it off, replaced the button and tried the keyless go again. Still receiving "Key Not Recognized" message.
