Gas in my S550?
Bottom line on octane and additives - lower octane and omitted additives will reduce performance and accelerate wear and tear. Purely an owners call.
Anyone know the comp ratio on a 550? Just curious.
Lesson of the day... being a cheap *** will cost you more on the future
2008 S550
2012 Corvette
What exactly are you referring to when you say 101 or better? If you're talking about octane, then pass that pipe over here. 101 is racing gas. You'll blow up any passenger car motor if you run that stuff too long.
The problem with regular gas is that it does not have the needed detergents to prevent carbon deposits which are the bane of most mb engines. Thus i imagine if you use 87 stateside (93 in Europe) and you use periodically chevron techron additive it should work alright.
Said that- if anybody puts regular in their modern Benzes they should not be allowed to own such vehicles.
Replying to correct a wives tale.
Running higher octane in an engine not designed for it does two things.... ensures the engine will not knock and burns a lot more dollars.
High octane will NOT damage an engine.
LOW octane can and does result in engine damage when engine management is unable to control knock.
High Octane fuel ignites at higher temperatures - in an engine not designed / tuned to use it - the mix burning at its optimal rate now occurs when the piston is now lower down the bore (as it starts later) so it will make LESS power - and the later burn also raises exhaust valve temps making it more likely to wear a valve and its seat
But remember other factors come in to play - where its often better fuel, so the loss (in an engine not meant to have high octane fuel) MIGHT be mitigated by other benefits in the fuel - plus all the extra cost additives could help - and then of course in today's messed up world - usually High Octane Premium Fuels gets a much lower / no Ethanol death content - so it will be a more energy dense fuel
10% ethanol content = 6% less GO !!!!!
Also contrary to most internet fiction, 87 and 93 top tier gas both have excellent additive packages to the base fuel.
Pre-ignition is an uncontrolled combustion event which occurs before the spark event.
Knock (pinging) is the actual noise that can be audibly heard if detonation is bad enough. Most OEM knock sensors are basically microphones tuned to listen for a specific frequency to detect this noise. When someone is describing knock, they are generally referring to detonation.
AKA Euroland units - 92 Octane - when normal western leaded fuel from 1960 to 1980s was always 98 Octane - so the engine's cope no problem so long as the ignition is retarded - in the old days - up to 1995 there was an 1.5" round black electrical plug under the bonnet and you moved pins to re-tune to low octane fuels
with alloy heads, modern materials and engineering tolerances, modern combustion chamber design, modern cooling systems with electrical fans, electronic engine management, reliable fuel quality, good oils, etc. there is little likelihood of knock - unless you didn't turn that ignition adjuster on 1970 to 1990 cars - and after year 2000 or so, its all done for you, managed by electronic knock sensors - all that really changes in today's world is tiny performance and fuel consumption drop - but unless racing a mate in an identical car (but with different fuels) whilst towing a heavy trailer up a 8500 ft high mountain you'll not really notice it....
http://www.w124performance.com/docs/...adaptation.pdf
