my S55O Wont Start! Help!
Subscribe
May 27, 2013 | 08:13 AM
Guys
i have an 07 s550, my problems begun about a month ago. I drove it to airport, turned the car off, stepped out for 5mins, came back to turn it on, it wont start.so I ended up towing it to a repair shop. The started battery was replaced with a new one and everything seemed to be back to normal. However, i drove it for a couple of hours today, made a quick stop at the gas station, and i wont start back up. I dont know whats wrong. the interior lights and all electronics are working well. It just wont start. i replaced the starter battery a month ago. What do you guys suggest? could it be the second battery in the trunk? thanks
Reply 0
May 27, 2013 | 01:12 PM
Startermotor and/or starter-solenoid dodgy ?
You could measure if power getting up to startermotor; if it does then ,that's the culprit.
Don't think its the acc. battery though..
Reply 0
May 27, 2013 | 02:21 PM
location of starter solenoid
thanks marthyh,
Can you please tell me where to locate the starter solenoid? i was told to remove it and have it tested to see if its faulty. ive been looking under the hood but just cant seem to locate the starter/starter solenoid. thanks
Reply 0
May 27, 2013 | 04:48 PM
Call Mercedes road side assistance. They will come out for free and will diagnose the problem. Service is available 24 hours per day.
If you have MBrace, press the button in your vehicle. If not, call the phone number.
1-800-FOR-MERCEDES (1-800-367-6372)
Throughout the life of your Mercedes-Benz, a Roadside Assistance expert is just a toll-free call away. Call 1-800-FOR-MERCEDES (1-800-367-6372) for assistance any time you're on the road, day or night, if you have a problem related to your Mercedes-Benz.
If you ever need assistance while traveling in your Mercedes-Benz, just call 1-800-FOR-MERCEDES (1-800-367-6372) for our 24-Hour Roadside Assistance. Our Roadside Assistance Experts know Mercedes-Benz automobiles, and they're well prepared to handle unforeseen roadside complications. And here's a reassuring fact: Every Mercedes-Benz in the U.S. - no matter how old, how many miles it's logged or how many owners it's had - qualifies for Roadside Assistance, 24 hours a day, 365 days a year.
Roadside Assistance repairs could involve charges for services and parts. Depending on the circumstances, an outside service may provide Roadside Assistance repairs at the discretion of Mercedes-Benz USA LLC.
Reply 0
May 27, 2013 | 04:51 PM
Quote: Call Mercedes road side assistance. They will come out for free and will diagnose the problem. Service is available 24 hours per day.
I immediately regret buying a BMW after reading this..
Reply 0
May 27, 2013 | 10:12 PM
a little more info would be useful. Does it crank at all? If it cranks, is it a strong crank all the way? any unusual sounds?
Reply 0
Apr 9, 2014 | 05:58 PM
Same Issue ..2008 S-550 Will not Crank .Lights work but no Crank
Good day All :
Can some one please assist me ?
I have a 2008 S-550 ..Few days ago I was driving ..Stooped for a coffee
Then I try to start the car and it will not Crank !!! all the lights are on .
I tested the front Battery and the back and they show Strong Voltage !!
I Tap'd on the Starter and try to start but no luck !
Mercedes Dealer did scan and it show'd nothing wrong !!
I am Scared if it the Engine seized ... that's a lot of Money but if it did .. it should Crank !!
Also ...Could it be a fuel Issue ??
If we change the Starter and it is still not cranking , what shall I do ?
Thx
Reply 0
Dec 9, 2014 | 05:48 PM
I am having the exact same problem with my 2011 s550. Car runs perfectly fine and then randomly won't start. I'll wait a few minutes and it cranks and runs just fine. It's been to the dealership 5 times and they cannot replicate the problem. Any advice would be great! I am contemplating just getting rid of the car as a last resort
Reply 0
Dec 11, 2014 | 11:10 PM
No crank no start
I'm new here and want to help im no expert but I have had every problem you can think of with my s 600. (I LOVE THIS CAR!!!!) Check the crank shaft position sensor. It 's behind the engine in between the fire wall and engine. Hard to reach but simple to do.
With a bad crank shaft position sensor it will work while cold and so you can start and drive just fine just as long as you don't shut the engine off. If you do you'll have to wait until it cools. Then it will start.
Reply 0
Dec 11, 2014 | 11:54 PM
I thought CPS symptoms were the car tries to crank but won't start?
Reply 0
Dec 12, 2014 | 12:49 AM
Quote: I thought CPS symptoms were the car tries to crank but won't start?
Yes your right in most cases but in the case of my s600 I would turn the key (nothing) then again nothing then after about a half hour of letting the car sit it would crank and start right away. Sometimes it would crank no start sometime no crank no start.
Reply 0
Subscribe
Currently Active Users (1)
