Service Issues
While I had the car there, I told them to go ahead and perform service C since it was coming up soon too.
I got the car back and while driving I noticed that the alignment of the car was not straight anymore (you had to hold the steering at an angle to drive straight)
Not only that, but in the write up it says that they check tire alignment for the C service (clearly did not) and checked and set tire pressure (all tires are different pressures, did not perform at all).
There were oil marks on the seat from the mechanics and worst of all they changed my seat memory.
Usually I have gotten good service in the past but this time everything was so careless. There's probably a ton more services that they didnt even perform I have a feeling.
Is there a way to revert back to old seat memory settings?
yes I understand thats what most likely happened. But I paid money for a C service and in the service write up it says they performed and check the alignment, which they clearly did not.
If that is not an option,should go and find an enthousiast dealer with love for the vehicule,for me this means not getting to the b%^& MB-dealer around the corner where I live, but taking an hour or so to get to a really good MB-dealer..
Not that big of a deal to reposition and store your seat positions properly ,when drivng a couple of hours(only 3 positions to be found).Especially you now know roughly how it should be exactly.. if this makes any sense?
