W221 knocking sound at low speeds
Old Jul 16, 2013 | 05:11 PM
aigarssilins's Avatar
Mercedes Benz S320 w221
Hello I have w221 diesel with airmatic. The problem is that my car makes not very loud not rhytmical knocking sounds ONLY at low speeds (until 50 km/h). This sound also appears when I sharply turn my steering wheel with 3 inch amplitude. This sound also appears when outside the car pushing down the front fender. Almost forgot - this sound comes from front left side when car is quite enough warm.
Did you have such problems. Please advice. Thanks in advance.
Old Jul 17, 2013 | 01:08 AM
malahhaor's Avatar
06 Carrera4
wheel bering might be bad if the sound is constant while on smooth roads. if sound appears when bumpy, then it could be control arm. Take it to mechanic, lift the car, check suspension.
Old Jul 17, 2013 | 06:42 AM
marthyh's Avatar
S500
Yeah could be the suspension bushings ,quite common on the W221 for what I have read so far.
Old Jul 17, 2013 | 03:26 PM
Hi please describe wht do you mean by suspension bushings? Did you have such issue?
Old Jul 18, 2013 | 04:17 AM
marthyh's Avatar
S500
The bushings are the mounts onto where the suspension arms are mounted and the arms swivel around these points.
Bushings are usually made of a sort of rubber or similar nylon material that over time degrades because of this movement/load and the weather/temperature.
Old Oct 21, 2013 | 02:44 PM
tgeorgiev951's Avatar
w221 Mercedes S320 cdi
front right knocking
hello!!
did you solve the problem??
it seem that i have the same issue and i have allready changed the stabiliser bar,bushing,and the knocking doesent go away.
b.r
Old Oct 22, 2013 | 04:03 AM
jwxspoon's Avatar
08 S-550, 03 BMW Z4, 02 Jeep Wrangler
Early in with my 2008 I had a line, I want to say it was a brake line, slapping against the bottom of the car periodically. My tire people found it and fixed the issue.
Old Oct 22, 2013 | 05:20 AM
Hi. Thanks for reply. Did you have the same knocking only in warm/hot weather? Please tell in details, what do you mean by brake line?
