Navigation no longer working
Old Dec 8, 2014 | 03:49 PM
Diesel Benz's Avatar
Are you referring to http://www.mbgtc.de ? They do recycle parts but they say that 80% of the parts come from their development departments and their own fleet.
I have bought a few parts from them.
Old Mar 31, 2017 | 10:23 AM
JOECC's Avatar
2009 S550 4MATIC
Hi- Just reviewing this as this just happened to me. I have an '09 S550 4MATIC. All of COMMAND System working except Navigation. I bought a disc update from MBUSA but it would not load/update. It seems from the thread that two methods have worked: a) do nothing, it suddenly stared to work again, and b) replace the HDD.
Three questions: 1) Any thoughts on what would cause NAV to fail and then start working again. 2) Any new information or progress on diagnosing/repairing the problem? 3) Any info on how common/widespread the problem is?
Old Apr 1, 2017 | 09:40 PM
Nuru's Avatar
S350 BT 4MATIC
Hello DB, I just saw this response, sorry for the really late reply! I dunno, as I only heard from someone via email from the DE
Thanks for the link!
Old Mar 9, 2018 | 03:20 PM
amriyaz's Avatar
Mercedes S550 2015
Where is the HU hard disk drive located?
Originally Posted by gapcobenz
The HDD in these HU is normally a Hitachi 20GB. I used the Samsung 30GB HDD for a while. Now when I repair these units I use an IDE to CF adaptor and fit a 32GB compact flash card. I clone a working HDD and no more problems. The HU reads navigation and other functions much quicker. With most navigation faults the HDD is the problem.
Can you please tell me where exactly is the HU system hard drive located that stores the GPS navigation maps? Is it under the HU unit or in the rear trunk? is the HDD in 2007 Mercedes S550 (w221) a 20Gb or 40Gb? is it 2.5" or 3.5" form factor? I will appreciate your answers. Thanks.
Old Mar 9, 2018 | 10:56 PM
amriyaz's Avatar
Mercedes S550 2015
1
_
Old Mar 10, 2018 | 09:53 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
What kind of solid state drive and interface did you use? Most SSD's are SATA, did you use some kind of converter or did you use PATA SSD?
Old Apr 1, 2018 | 05:10 AM
  #32
amriyaz's Avatar
Mercedes S550 2015
IDE to CF Adapter model #
I have tried few IDE 44-pin to CF adapters but they all have issues working with the w221 Command Unit. Can you please tell me which IDE to CF adapters did you use that worked? A model #, name/picture or URL will be very helpful. Thanks.
Old Apr 13, 2018 | 09:24 PM
  #33
amriyaz's Avatar
Mercedes S550 2015
I have a ready to go Navigation system Hard Disk Drive (HDD) with all the software on
I have a ready to go Toshiba, 20Gb, model # MK2028GAC, Navigation system Hard Disk Drive (HDD) with all the original maps (latest map command update 2015/2016 NTG3 v15.0 US version installed) software and other configuration settings on it. This HDD is a direct fitment for 2007-2009 Mercedes S550. If your navigation HDD is dead or is dying, privately message (PM) me if you are interested in buying my hard drive. This is a rare item and troubleshooting/replacement at the MBZ dealership can be very expensive. Just so that you know if your HDD dies it not only affects the navigation system but also causes problem with the climate control settings and other features managed by the Command Unit.
Old Nov 13, 2018 | 11:50 PM
  #34
amriyaz's Avatar
Mercedes S550 2015
I still have the replacement navigation hard drive available. If someone wants to buy it, message me privately. Thanks!
Old Nov 14, 2018 | 09:59 AM
  #35
megacrazy's Avatar
CLK55 W209, CL63 W216
Details on SSD upgrade are located here:
https://mbworld.org/forums/cl-class-...placement.html
Old Nov 14, 2018 | 01:14 PM
  #36
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Will be doing this fix Friday, adapter and 32GB mSATA drive ordered. My Navi is in the " software was updated and to insert the map DVD " mode, so I'll be trying the replace/recreate method. Will reply with the cheesy goodness and process I followed if different from yours. Thanks for your efforts!
Old Nov 15, 2018 | 09:40 AM
  #37
megacrazy's Avatar
Definitely let us know if your experience varies. My SSD has been fine in cold/hot weather...no issues so far. Installed an Android head unit recently but COMAND is still chugging along.
Old Nov 17, 2018 | 01:19 PM
  #38
dlafever's Avatar
So far;
- Original Toshiba HDD replaced with 32GB mSata connected via the Ableconn IIDE-MSAT mSATA SSD to 2.5-Inch IDE Adapter Converter
- Attempted load of Update 15 DVD Maps, this time instead of the standard "software was updated and to insert the map DVD" message persisting, I got a confirmation that the v15 DVD was the one I wanted to load.
- Still failed after attempting the load.
Next steps;
- Attempt to recover the QNX4 data from the original drive, at least the partition structure
- Attempt to load the original map set from SDS (perhaps the update DVD is just for updates?)
So it looks like just loading from a blank drive is not an option, unless it will work from SDS.
Old Nov 17, 2018 | 01:34 PM
  #39
megacrazy's Avatar
So far;
Next steps;
That's strange. You're on NTG3 correct? What message are you getting?
I made a copy of the original drive when I installed the ssd. It was after installing the latest firmware via SDS. If you need it, hit me up via pm.
Old Jan 29, 2024 | 06:24 AM
  #40
danvel223@'s Avatar
Merc S Class
Originally Posted by new550
Anyone know the type size brand etc of the hard drive ? A complete duplication should work if drive is 100% identical ?
Drive is a TOSHIBA MQ01ABFO32 320G Byte .
Old Jan 29, 2024 | 06:28 AM
  #41
danvel223@'s Avatar
Merc S Class
You can download the software from MBTOOLS and copy it to a USB and load it from there.. You will also need buy the relative activation key number on same site.
Old Jan 29, 2024 | 06:33 AM
  #42
danvel223@'s Avatar
Merc S Class
I have same problem with NAVI maps and I reckon problem is the Hard drive . However I am worried that the Hard Drive in the car may contain some piece of code to match it to the VIN of the car or something like that . i.e. not just the maps . If I replace the entire Head Unit assembly with a second hand one I purchased I do not have the ' anti theft code ' for the radio end.
Old Jan 29, 2024 | 07:01 AM
  #43
danvel223@'s Avatar
Merc S Class
Does a ' New unit ' come with any sort of ' anti theft code ' number etc ? tia.
Old Jan 29, 2024 | 08:38 AM
  #44
BOTUS's Avatar
S500
I don't think the older NTG3 has anti theft... might
anti theft in radios has only ever inconvenienced the owner or the garage working on legitimate cars - the whole idea is ridiculous
there is going to to be basic coding set up for the seats, massage, heater, not sure if that's on a chip of part of the stuff on the hard-drive
but we have a member who can help out and do stuff with dealer tools if you join his club....
Old Jan 29, 2024 | 08:41 AM
  #45
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
BenzNinja on here for the win !!
Old Jan 29, 2024 | 10:45 AM
  #46
danvel223@'s Avatar
Merc S Class
Who's club do you refer to ? How do I join ? tia.
Old Jan 29, 2024 | 10:56 AM
  #47
BOTUS's Avatar
S500
I know most of the users seem to be in the USA - but it doesn't mean the experts are
https://mbworld.org/forums/s-class-w...a-s-n-1-a.html
