Coil Code misfire?
Old Aug 20, 2013 | 07:08 PM
kblair3d's Avatar
2014 GL 450
Coil Code misfire?
I have a code P0352 or misfire on # 2 cinder I changed out the coil and still a reoccurring problem any suggestions ? Is this a computer issue
Old Aug 21, 2013 | 10:51 AM
kblair3d's Avatar
2014 GL 450
bimp
Old Aug 21, 2013 | 02:45 PM
marthyh's Avatar
S500
Have you changed the appropriate spark-plug as well , as a matter I would change all ..
But you could start swapping two spark-plugs and/or coils first, as a matter of deduction?
Old Aug 22, 2013 | 09:18 AM
kblair3d's Avatar
2014 GL 450
yes thanks for the reply, both #1 and #2 were swapped out # 2 was a new coil pack and there rest remained being there was no error code. I was leading towards two other choices one would be the ECU or believe it or not the Fuel Pump. When Im riding sometimes I feel the MisFire and other times it feels on a cold start its shaky the car itself rocks.
WHICH also leads me away from the ECU because the ECU may react to the engines heat and cause some malfunction or whatever... and the Fuel Pump, well I cant see how that could be the message if the error code is only leading to the "P" code. ugh. AND the dealership is going to cause $K's to simply target.
Old Dec 6, 2013 | 03:11 PM
tri-color's Avatar
Mercedes benz
I have similar problem, I have a misfire on Cylinder 3 (Passenger side), but I was wondering, is it possible to replace a single coil?
