Change the regular instrument cluster to /////AMG
Old Mar 8, 2015 | 05:11 AM
M.Azzahrani's Avatar
W220
Mashallah Alghamdi, thats quite impressive. Exquisite taste indeed.
Old Oct 14, 2015 | 02:12 PM
jrumman's Avatar
you can change your original icm to amg by writing the amg epprom . that is all . no need to buy new one
Old Apr 8, 2018 | 11:10 AM
sizzer's Avatar
S320
How?
Old Apr 9, 2018 | 01:21 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Send your cluster to me and I can change your LCD panel to an S63 or S65 - your choice. Will have the red needle for the speedometer (but the analog gauges of course stay the same). Odometer will be at 000000 and will need to be taught in to Drive Authorization System. As soon as this is done, it will pull the correct mileage from the EZS. Options will be transferred over so Navi Telephone, Vehicle, Assistance, etc., will be intact. PM if interested.
Difference in S63 and S65 clusters are 200MPH speedometer and 220MPH speedometer, respectively. Will also have AMG race timer function on both.
If you want a very unique look, you can go with the BRABUS speedometer with 220MPH range with matching font of existing cluster:
Old Aug 11, 2019 | 12:24 PM
Mking4469's Avatar
2008 sl55, 2003 sl500, 2011 s550 , 2012 s65
Convert cluster to s65
I'm looking for a s63 or s65 cluster.
Old Feb 13, 2020 | 11:29 AM
XLR8_R's Avatar
W221 S500L
I would like to know more about Brabus one
BRABUS
hello how much is the brabus one or do i have to code it.
Old Jun 5, 2020 | 02:54 PM
  #32
steve delacruz's Avatar
2013 W221 s550 4matic
pm me im interested
Old Aug 16, 2020 | 12:17 AM
  #33
///AMG Janahi's Avatar
CL 500 Brabus
Originally Posted by ymalghamdi
Hello everyone,
I have changed my regular instrument cluster to 65 AMG (facelift), I will put all pictures to explain how to installation.
This is the final result:
All my thank's are to Mr. Steve from MBenzNL
Can you program the gauge cluster from a normal km/h 2007 CL500 to the Brabus Cluster
Old Aug 16, 2020 | 02:29 AM
  #34
pmercury's Avatar
member
CL
yes of course, its just a matter of unsoldering eeproms, some can even do it without
and having a Brabus cluster dump of course.......
Old Aug 16, 2020 | 02:31 AM
  #35
CL 500 Brabus
Do you know anyone who does it ? Or can I do it through a program sent online by the guy who does it .
Old Aug 16, 2020 | 02:54 AM
  #36
pmercury's Avatar
member
CL
you will need at minimum a C4 sd connect hardware clone.
Old Aug 16, 2020 | 03:13 AM
  #37
CL 500 Brabus
that can be managed then who is going to send me the Brabus map or software to install in to the car
Old Aug 16, 2020 | 03:36 AM
  #38
pmercury's Avatar
member
CL
you mean that you know how to use vediamo ?
Old Aug 16, 2020 | 04:14 AM
  #39
CL 500 Brabus
I really don’t know or how it works just want it done without sending out my cluster - probably can take it some one that’s familiar with those things . The guy I deal with has the AMG 63 and 65 Speedo programs not the Brabus
Old Aug 16, 2020 | 04:46 AM
  #40
pmercury's Avatar
member
CL
Here you go
I don't have the flash, this is the eeprom
File Type: rar
Old Mar 5, 2023 | 07:08 PM
  #41
gavejoke's Avatar
w221
Hello can you guide me how to do it ?
Old Mar 5, 2023 | 07:09 PM
  #42
gavejoke's Avatar
w221
Hello everyone,
can you guide me how to do it please ?
Old Nov 26, 2023 | 02:29 PM
  #43
Marco antonio's Avatar
W221 s550
Hello
BRABUS
i would like to send you my cluster. Are you still doing this?
Old Nov 26, 2023 | 03:55 PM
  #44
BOTUS's Avatar
S500
I'd heard the AMG ones get a larger size chip... funny never read you can pay mix and match - I have an AMG cluster sitting in the garage
it irritates me they can't make the early standard cars have the user menu to toggle the speedo between kph and mph - have to connect up to xentry and get confused in a bunch of menus
then the AMG menu set isn't an option that's just turned off - it not there in the brain of lesser cars
Old Nov 26, 2023 | 04:42 PM
  #45
W221 s550
Cluster
are you selling the amg clister? I have a2008 s560. I can toggle between mph/kph .i use mph tho. Or can i just get someone to adjust my cluster. I like the amg version bcuz im doing the 10 inch touchscreen radio soon from seicane
Old Nov 26, 2023 | 04:47 PM
  #46
BOTUS's Avatar
S500
by mid 2007 they added the kph / mph user menu - but its not able to go on early cars
I'm in the UK, its a RHD cluster and I was planning on keeping it (sorry)
Old Nov 27, 2023 | 08:22 AM
  #47
doni01's Avatar
2013 S550 4MATIC
I had mine done a while back when I purchased the car. I always loved the way the car greeted you when you opened/unlocked the door with the AMG Logo on the cluster. I swapped mine with an amg S63 one from the same year ( 2013 ) but work needs to be done via Vediamo and you need to have some knowledge in German in order to have everything working. Below is how it looks like. Before and after. Exuse the smudges, pics were taken right after the swap...
Old Feb 14, 2024 | 04:28 PM
  #48
magnethelm's Avatar
W220
Cluster
just one comment on this - that’s a S65/CL65 cluster as it goes to 7k rpm
The S63/CL63 clusters go to 8k rpm afaik
Old Mar 20, 2025 | 05:18 AM
  #49
Hamdan_1992's Avatar
Originally Posted by JT.S550
Thanks to Yousef, I have converted my speedometer on my s550 to a s63 speedometer and I'm in process of upgrading my airbag as well,
Thanks again Yousef
could you please tell me how you did it?
Old Mar 20, 2025 | 05:31 AM
  #50
BOTUS's Avatar
S500
check the pictures above the dials on the minor gauges get the awful style of the AMG speedo - so even if you programme just the dial of the LCD speedo it will look odd
if changing the minor dials graphics you need to strip and pull needles etc. and on some variant the red line is in a different place
coding all the option variants if swapping the entire cluster is a bit of a fight and needs dealer tools
and sorting the mileage is yet another bit of fun - since forever tweaking the miles to match is not so easy - and on these other components mileage records in the car will try to fight you
