Possible 4 staggered wheels on 4 matic?
Old Jan 15, 2014 | 12:44 AM
1bad540's Avatar
s550 Diamond white amg pano
Hey guys going to look at a car tmrw and was wondering if I can put staggered wheels on a 4 matic.?
Old Jan 15, 2014 | 08:00 AM
wilassasin's Avatar
2013 S550 4matic (AMG sport package), 2016 Corvette Stingray.
Im sure that you can, its been done b4 plus the CLS 4matic and C-Class both have a factory staggered set up. Call a few dealers parts & service departments and see what they say, during my search I even called some dealers in Cali and they told me no or that they did not know....Called a few wheel places that said they do it all the time on the 4matic sclass, im sure a few others will chime in that has actually done it but I just decided against it.
Although this is not an issue with the 7 series Xdrives as you know, keep in mind the factory spec that the S-Class offers is a wider wheel/tire set up with a lower profile than the bimmers do. So basically the SClass is running a 20 inch set up as follows: 255/35/20
The 19 inch wheel set up is 255/40/19, so as you can see both are very wide with a low enough profile that if u didnt want to stagger would be suffice.
Old Jan 15, 2014 | 09:01 AM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
Just make certain to keep the overall diameter of the wheel/tire combination the same between front and rear.
Old Jan 15, 2014 | 02:12 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Although this is not an issue with the & series Xdrives as you know, keep in mind the factory spec that the S-Class offers is a wider wheel/tire set up with a lower profile than the bimmers do. So basically the SClass is running a 20 inch set up as follows: 255/35/20
+1 you can def do it
Old Jan 15, 2014 | 06:13 PM
Cruespeed's Avatar
Mercedes S550
I have an 07 S550 4Matic and I have a staggered set up. 22x9 and 22x10.5 with 255/30 and 295/25.
Old Jan 15, 2014 | 07:15 PM
any pics? did you use a spacer up front?
Old Jan 15, 2014 | 10:53 PM
1bad540's Avatar
Thanks guys!! Pic wouldn't hurt
Old Jan 16, 2014 | 11:55 PM
JT.S550's Avatar
Mercedes GL conversion
2007 s550 4matic with staggered OEM s63 wheels
255/35/20 front 8.5
275/35/20 rear. 9.5
