Static on FM only, any fix
Old Mar 30, 2014 | 05:19 AM
terrymargate's Avatar
merdeces s320
Have s320 cdi, yesterday was changing FM stations and static appeared. it is on almost every channel apart from radio 2 or 4
It still finds new stations as I drive along the motorway, but they are just static
all other frequencies are fine AM MW and SW
is there a fuse that cover the fm antenna, or any other fix to try, I checked all fuses in rear SAM and they are fine
Old Mar 31, 2014 | 06:03 AM
marthyh's Avatar
S500
Not sure wether there would be a fuse but you can do a test with Xentry: go into the sub-menu 'tuner' and check how your antenna performs.
Old Mar 31, 2014 | 02:47 PM
ImInPA's Avatar
2012 S350 Bluetec 4Matic, Diamond White, P2
I had this once. Here is what fixed it for me: A total reboot of the COMAND system. Press and hold the "eject button" on the CD/DVD changer until the system reboots. When mine finished rebooting, the static was gone completely. Hope this works for you as well.
Old Mar 31, 2014 | 04:11 PM
merdeces s320
thanks for the response, will try xentry tomorrow, have already tried command reboot, made no difference
Old Apr 1, 2014 | 09:12 AM
ImInPA's Avatar
For me, the static was in every source: FM, SAT, iPod, etc. Sorry that didn't work. What is Xentry?
