Xenon wont get off ?
I have a MB W221 '07 with a problem with the HID lights. If I put my lightswitch on mode "0" the xenon just still burning and wont get off.
Are there anny sulution for this kind of issue, I will be glad to hear.
As the poster above stated, in the US there is an option called Daytime Running Lamps that you can enable or disable, which will cause the lamps to illuminate when the engine is running. If you are in another country this option may or may not be there (in Canada daytime running lamps are mandatory and the menu option is not there, therefore it is no possible to disable them).
If you have a 2010-2012, since they have LED daytime running lamps, this probably would not apply as I don't think you can make the headlamps burn short of turning them on regularly.
