Airmatic Malfunction - Complex problem
Old Nov 8, 2014 | 12:36 AM
benz_addict's Avatar
V12TT
2007 S550 4Matic
STAR Error codes shown:
5111 Y36/6b1 (Airmatic Pressure Sensor): Signal Implausible
5287 Suspension strut is Implausible
Suspension wasn't lifting up. SDS tests to compressor confirmed bad pump so that has been replaced. Wiring harness to PUMP look fine. However the car NOW rises up BUT these fault codes still are appearing with "Airmatic malfunction" displaying on dash as soon as you start the engine.
Where is the pressure sensor located? Is it built into the valve block? What else should I check? Where would the common broken wires be?
Thank you in advance.
Old Nov 8, 2014 | 08:58 AM
Quadcammer's Avatar
96 and 08 911 turbos
Yes, the pressure sensor is screwed into the valve block. You can replace it separately.
Using DAS, I'd check to see what the pressure sensor is telling you. I would probably also run through the pneumatic tests on the block. If that comes back ok and the N51 module is communicating with DAS ok, then Id say your valve block is doing ok.
Start there and see what you get.
Old Jul 28, 2017 | 10:29 AM
S430Sport's Avatar
2008 S550
Any update on this?
Old Aug 11, 2017 | 01:59 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
oops, wrong thread
Old Aug 11, 2017 | 02:22 PM
mrmotoguzzi00's Avatar
Well done Chris!
Mike
Old Sep 15, 2021 | 08:02 PM
Bexycoal's Avatar
W166 Amg63
Error code keeps coming back
Spoiler
