Anyone ever changed their ambient lighting on their 221?
Old 08-07-2020, 11:54 AM
  #101
Minh's Avatar
S350 2008
My car has no option for interior ambient light and I want to retrofit for ít. I have purchased wood trim for 04 doors and instrument panel with ambient light equipped. Perhaps retrofit interior ambient light for 04 doors shoudn't be any problem for me because I know the pins on door control module supply power for ambient light, however I don't know how the interior ambient light on instrument panel is powered? do you know where the below ambient light connector need to be connected in order to get it powered?
Old 08-08-2020, 11:48 PM
  #102
megacrazy's Avatar
CLK55 W209, CL63 W216
Check out the w216 AMG forum for my progress on an ambient light system. The w216 version is almost done. I already have the parts I need to start designing for the w221. Might be worth the wait instead of trying to retrofit the stock system. You’ll still need the trim pieces as well as an android headunit preferably.
Old 08-10-2020, 08:27 AM
  #103
Minh's Avatar
S350 2008
I successfully completed retrofit interior ambient light for my car, below is the detail
You need to open command wwith DAS/Xentry then activate ambient interior lights under Development Data
Once option activated then you will have a menu on command to control ambient light
Retrofit ambient light for instrument cluster is quite straight forward, the ambient light connector is connected to AC control module for power.
This is the connector connect door control module to door panel, they supply power for ambient interior light wwith pin 7&8 (my car has no ambient interior light then this connector supply a power for tiny led at door handle)
Here the test led I connect to door control module to verify power supply
This is a tinny Led on door handle, wiring is connect to pin 7&8 of door control module then for ambient light at the door, o just soldering interior led light to these cable.
This is a connector of the ambient led light on the wood trim of the door, since I have no connector then I used ribbon cable as connector and the other end of ribbon cable I soldering it parallel on the tinny led as mentioned above
Here the result, it's amazing
On the handle hole, you see a tinny led light up, it's the led I mentioned earlier
Beautiful.
Old 08-10-2020, 12:39 PM
  #104
Judge_Ito's Avatar
2007 S550, old cars now gone, 2000 S500, 1992 400SE, 1988 300E, 1986 300E, 1975 450 SEL, 1972 220/8
Originally Posted by therealmerc
Hi anyone have contact info for MBModing? Very important in regards to a project. I sent a private message & email thru here but no response yet.
Thanks in advance!
Merc
He had a heart attack while on vacation and has passed away
His wife has kept their shop open but no more custom work, just window tint install.
Old 08-11-2020, 07:22 PM
  #105
Benzman33's Avatar
2024 GLE 350
RIP He did great work
Old 11-17-2020, 04:22 AM
  #106
Jefe47's Avatar
w221
ambient lighting upgrade
a place called incarpassion.com makes ambient light kit for the w221 & w216 that can be controlled via steering wheel seems like its plug & play
Old 01-09-2021, 03:23 AM
  #107
SakBenzi's Avatar
Mercedes w221
Help
i have a 2010 s class and am having these issues, what led light kit did you use? And do you have link to how you did?
Originally Posted by mbmoding
On my 2010 S550, it supposed to have 3 colors but really only 2 noticeable difference. I checked what lights up the plastic bars and there are 2 tiny leds, one is blue and the other is kind of amber. It's one color or the other or mixed. I didn't really like the color so I added my own leds and now my new colors are red, blue, and purple. The colors are much cleaner and brighter than stock. The comand operates and dims the new lights. I have also added a module to further the color options and use. I can do any color choices and have it also do patterns and go with the music if wanted. The big thing is now I can choose a much better color option. In fact the choices are far better than the new S class with limited color range.
Old 08-16-2021, 06:22 AM
  #108
incarpassion's Avatar
W213
Can check this thread for the product: https://mbworld.org/forums/s-class-w...ent-light.html
Quick Reply: Anyone ever changed their ambient lighting on their 221?
