This Speaker Upgrade Is So Cheap I'm Reluctant To Post The Price Pi
I thought the S Class is only a 7 channel amp? That implies that some of the speakers are running in parallel. If that's the case how did you come up with 12 channels?
My main goal is to change the speakers and make the entire system louder while keeping OEM features such as steering buttons.
Upconverting applies to video, but not audio, and it's a process that can make a lower resolution video source look better on a higher res monitor.
For example, if you have an HD TV at 1080p, and you play a lower res DVD through an upconverter, the upconverter will add the extra scanning lines by "guessing" what would be there based on what already is there. It's not really HD but it's cleaner looking. Basically no system can add back in digital information that isn't already there in the first place. So for example if you have an MP3 ripped at 128kb/sec and you re-rip it at 256kb, you'll get a larger file size but zero increase in quality.
In the car, the screen resolution is capped at 800 horizontal scan lines. You can feed it full on upconverted 4K but all you'll ever see is 800. You'll get much bigger file sizes but no improvement in quality so save the space and rip from Your Tube at no greater than 720p. (For the stuff you play in the car.)
"Lossless" and "Lossy" refer to the transcoding method used to rip audio. Lossless rips are bit-for-bit identical to the source material. Lossy rips use an algorithim to strip out musical data that would be masked by other musical data. Lossy is compressed, lossless is uncompressed.
Again, all roads lead back to the quality of the original source material. If you rip a CD lossless (FLAC or ALAC) you'll get CD quality playback. If you re-rip or re-encode a 256kb MP3 using lossless, you still get a 265kb MP3.
I did try the Amerisoft converter, downloading a 4k music video in full 4k quality. While the resulting video file was massive, the audio was still at a relatively low quality 125kb/sec. To test this yourself, download a 4k file onto your computer, then go to the file itself and right click, and select Properties, then Details and scroll down to the audio section.
Try ripping the same music video to DVD using both the highest quality original 4k source material on YouTube, and then rip the same at 720 and see if you see or hear a difference.
Consider swapping out just the 4" mid and factory tweeter in the front of your doors, and the 6.5" woofer and tweeters in the back of your doors. It would make quite a difference in quality.
So ignoring all the tech gobbledygook my point was that you could step down the resolution of your downloads, and get more material on a single DVD without losing any discernible quality in the car.
How does each individual speaker get it's on channel on the amp when using a 8 channel amp? How would you control the left/right & front/rear audio settings? That's the part I'm failing to understand.
My understanding is that the master controller in the Gateway distributes amplified signal to the speakers and can apportion signal based on inputs it receives from COMAND. So if you fade front, the Gateway "knows" and apportions more signal to the front, etc. It just seemed way too complicated and integrated to start hacking into for me, but I have seen a few 221s on here with full on aftermarket amps and speakers, but they're rare and I'm not sure how much OEM integration they retained. It seemed like they were gut jobs.
https://mbworld.org/forums/attachmen...udspeakers.pdf
I'm ordering four of the Goldwood speakers from the link right now. I will install in the front doors like you have shown BUT ...
You said its 4" in the rear deck right? or 6.5"? and you're not sure if the depth will work? if I'm understanding correctly. Do you plan on giving it a go? If so, let us know if it works or not. And add some pictures in!
I'd suggest doing the front doors first since they play more prominently and access is easier. The rear deck 4" are just surrounds and are more labor intensive to get to.
And get pics since you'll be the first to do these. I discovered them only after I had a $750 set of Focals installed in my front doors.
Hertz 163 which are 6.5", 3", 1" great reviews for SQ.
CDT Audio HD 832 which are 8", 4", 2" and is known for good mids.
http://www.cdtaudio.com/main_series/hd/hd842.htm
The 8 inch subwoofer has a mounting depth of 3.69” could this fit?
The Hertz 6.5" has a mounting death of 2.75" and a total depth of 3.11".
I'm leaning towards the Hertz because of the amazing SQ but would the CDT fit on the front doors?
I've had CDT Audio in my other car and you really don't need a subwoofer running some of their drivers...
But after all was said and done I realized that the front door 4" midrange speakers were the source of a lot of the problems and maybe my set of $750 Focal components was overkill. The issue was that there are very few 4" aftermarket woofers to choose from. The ones I found were either less desirable coaxials (woofer and tweeter in one) or very expensive 2 way components (separate woofer and a tweeter) like the Focals.
A couple weeks ago I was browsing a wholesale speaker component catalog (what can I tell you...I'm not a big sports guy and I need something to read in the crapper when my wife throws away the Victoria's Secret catalogues) and I came across the Goldwood GW-204 4" woofer. Goldwood typically makes 8 ohm drivers for home speaker building, but the 204 is a 4 ohm version, which is the standard for car audio.
As you can see, the Goldwood is quite a bit heftier than the stock Harman 4", with a huge shielded magnet and motor assembly. Some of that heft is actually the shielding but overall it's quite a bit more robust. But the best part is that the speaker cone on the Goldwood is conventional treated paper while the Harman is a plastic coated aluminum material Harman calls "Alumaprene". The metal cone material is why the Harman system sounds as thin and harsh as it does. There are five 4" Alumaprene speakers, and two 6.5" Alumaprene speakers in the W221.
I went ahead and ordered one and did a quick A/B listening test, adding a 1" silk dome tweeter to replicate the set-up in the front doors of the 221. My concern was that the much heartier Goldwood would be a power hog, but it was fine, taking only a little more volume than the Harman. It sounds warm, full and even develops a bit of midbass where the Harman bottoms out and distorts. Paired with the tweeter it sounded great. I wouldn't hesitate to install the Goldwoods in my car.
Mounting wise I tested the depth in my spare 221 front door module and it's fine. The Goldwoods (and every replacement 4" including my Focals) have a square 4 hole mount, where the stock speaker is a 3 hole triangular mount. You'd need to Dremmel off two of the mounting ears, like so:
Goldwood on left.
Now the price. Understand that Goldwood has no marketing expense at all. They don't have the hype of a name like "Bose" or "Harman/Kardon" where they could charge exorbitant prices for otherwise cheaply made components.
The Goldwoods are $22.56. For a pair. If you want to buy four and replace the two surround speakers on the rear deck, the per unit price drops to $10.19.
Link: http://www.parts-express.com/goldwoo...4-ohm--290-370
Here's a matching set of 6.5's for the W221 rear doors, $46.20 for the set.
Link: http://www.parts-express.com/goldwoo...4-ohm--290-351
