Differential fluid capacity
Old Mar 21, 2015 | 11:40 PM
khtruong0615's Avatar
2007 s550 4matic
Does anyone has information regarding the capacities of front and rear differential fluid for S550 4matic? I could not find it anywhere in WIS nor EPC.
Old Mar 22, 2015 | 12:20 AM
konigstiger's Avatar
'71 Pinto
Listed in OM under technical data:
Attached Thumbnails Differential fluid capacity-capture.jpg   Differential fluid capacity-capture2.jpg   Differential fluid capacity-capture3.jpg
Old Mar 22, 2015 | 10:28 AM
2007 s550 4matic
Thank you. It does not list 4matic in my manual. Is the front differential use the same amount?
Old Mar 22, 2015 | 11:51 AM
Nickthegreek's Avatar
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
Its somewhere between 0.7-0.9L I believe and i think you also have to remove the front axle shaft to fill. I dont think theres a fill plug
Old Mar 22, 2015 | 12:05 PM
For the front diff i would inspect to see if there is an obvious leak first. If not then leave it. I would wait until you have to do balljoints or bearrings and do it then when everything is out. Usually doesnt need to be changed until about 100k
Old Mar 22, 2015 | 12:17 PM
2007 s550 4matic
Thanks Nick. There is no info that I can find on this front diff in WIS. I'll do an thoroughly inspection.
Old Mar 22, 2015 | 01:39 PM
Yeah they did not properly document that. Im trying to find where i got the info from. Poorly thought out design having no fill plug.
