"Feather Tires" need advice
“Car got new tires and alignment”
. . .ONLY ALIGNMENT IS FRONT AND REAR TOE!
GONE ARE THE DAYS WHEN “FULL FRONT AND REAR WHEEL ALIGNMENT” MEANT JUST THAT.
At K-MAC we saw the need therefore to design, manufacture “precisely adjustable replacement bushings” for the front providing both Camber and Caster adjustment and with 3 times the adjustment range of the one position bolts.
For the rear also precise Camber adjustment with additional Toe adjustment to compensate for the new Camber facility.
The patented K-MAC design allows full precise ongoing front and rear adjustment capability – “single wrench” (no disassembly, on car, accurately under load).
To correctly resolve costly, premature inner edge tire wear, steering pull, improving traction, allowing to return to factory specs after curb knock damage, fitting wide profile tires / wheels, altering height or just the advantage to be able to change settings for “track days”.
YOU FIX IT RIGHT THE 1St. TIME WITH K-MAC – No more ongoing trips to dealers or alignment shops or constantly changing tire brands because of only Toe adjustment or the minimal adjustment offered from inaccurate one only position offset bolts!
Bonus is the 4 front (and the 4 rear) bushings also replace the highest wearing suspension bushes. The K-MAC patented design allows twice the load bearing area with the front bushes being 2 axis/self aligning without the use of oil and air voids. Result is improved brake, traction and steering response.
Also importantly K-MAC rear adjusters move lower arms/tires inwards when wanting to reduce inner edge tire wear/improve traction (unlike “Camber Arms” that move top of tires outwards diminishing essential clearance to outer fender).
All kits come with instructions and bush extraction/insertion tubes (MB World member Heiss Rod has kindly provided step by step picture sequence re front bush installation. See https://mbworld.org/forums/w211-amg/518431-k-mac-bushing-install-guide-w211-airmatic.html )
W221 Front kit (Camber and Caster) #502316K $480.
W221 Rear kit (Camber and Extra Toe) #502526K $480.
Including airmatic.
Special promotional price delivery for MB World members USA/CANADA $30 one kit or $40 for front and rear (average delivery time 3 – 4 days). Payment Visa, M/Card or PayPal.
