Proper lug bolt torque?
Old Apr 30, 2015 | 01:34 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Question Proper lug bolt torque?
Does anybody know the proper torque to use on the lug bolts of the W221? Also, what is the correct cold PSI for the 20" wheels on 35 series tires? I know my 18's call for 32, but I believe it is a little higher going to a 20" wheel with lower profile.
Old Apr 30, 2015 | 01:40 PM
WHPH28's Avatar
Depends on the weather
My cold psi is 34-35 and warms up to about 38.
Not 100% on tq but believe it depends on the lug nut size. I think mine is around 100ft lbs or a little less.
Old Apr 30, 2015 | 02:08 PM
triniexr's Avatar
2011 Mercedes S63 AMG
The torque should be set at 110 or 115 lbs.
As for the tire pressure, on my S63 the rear is 41 psi and front is 38.
The tires are 275 35 20 in the rear and 255 35 20 in front.
Old Apr 30, 2015 | 02:10 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Are those the tire pressures that are shown on your gas filler door?
Old Apr 30, 2015 | 02:36 PM
triniexr's Avatar
Yeah it is....
Old Apr 30, 2015 | 02:50 PM
WHPH28's Avatar
Old Apr 30, 2015 | 03:02 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Originally Posted by WHPH28
Is that from the S65 you test drove? It seems odd that the tire pressure would be different for the S63....unless it was a front end weight issue with the V12 vs the V8.
Old Apr 30, 2015 | 03:06 PM
WHPH28's Avatar
This is from an S65...not sure why it would be different from the S63 though unless the engine weight...
Old Apr 30, 2015 | 03:08 PM
WHPH28's Avatar
This is from an 08 S63
Old Apr 30, 2015 | 03:13 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Looks like I'll be going with 44 psi all around. Thank you kind sir.
Old May 11, 2015 | 07:24 AM
triniexr's Avatar
Oops... I was off in my previous post. This is what I took from my gas tank off my 2011 S63. I don't know if Canadian standards are different. I think I need to re-check all my tires now.
Old May 16, 2015 | 03:52 PM
Garticus's Avatar
W221/S550
I thought I read somewhere that the wheel lug bolt torque is 95-96 ft lbs. (130Nm)
Old May 16, 2015 | 04:18 PM
DaveW68's Avatar
Veteran: Army
2015 S550
I torqued mine to 100 lb/ft, so I think I'll be good to go.
Old May 19, 2015 | 07:57 AM
triniexr's Avatar
When I go to the dealership for service my receipt says that the tech re-torques my wheels to 115lbs so I was going based off that.
