Ordered loweirng links
Old Jul 4, 2015 | 04:09 PM
  #51
WHPH28's Avatar
Depends on the weather
Originally Posted by 1bad540
Did you do them yourself?
Yes...
Old Jul 5, 2015 | 03:20 PM
  #52
1bad540's Avatar
s550 Diamond white amg pano
Ive done lots a bmws never a benz, seems the fronts are like a brembo, pop the oins and the rattle clip and slide them back down, the rears you need to pull the caliper off? I assume the bolts are behind? do you know what size the bolts are? also did your wheels take the factory lugs? or you needed new ones? Looks great Im preparing to do a little modding myself.
Old Jul 5, 2015 | 03:28 PM
  #53
WHPH28's Avatar
It's easy. Just pull the caliper bolts, I think 7mm if I remember correctly and anti rattle clip. I pulled them off and just slid them back in as I wanted to inspect my rotors also. You should be able to just slide them out in place.
No, I had to use shorter lug nuts. They are 28mm.
Old Jul 5, 2015 | 03:32 PM
  #54
1bad540's Avatar
Ohh, why shorter lugs?
Old Jul 5, 2015 | 03:34 PM
  #55
WHPH28's Avatar
Most aftermarket wheels take the shorter lug nuts as oem are too long.
Old Jul 5, 2015 | 07:43 PM
  #56
1bad540's Avatar
Interesting, how do u know which bolts to get?
Old Jul 5, 2015 | 07:57 PM
  #57
WHPH28's Avatar
28mm seems to be the size for a majority of the aftermarket wheels. When you buy new wheels they will tell you what size you need. I used 28mm for 2 different sets of wheels for my 550 and 600. Keep spare oem lug nuts in your trunk because if you get a flat you will need them if you put the spare on.
Old Jul 8, 2015 | 12:35 PM
  #58
1bad540's Avatar
so I got my wheels and tires ordered and also the ake pads and new sensors, can I get these same lowering links you have? Or mine is air s I need diff ones?
Old Jul 8, 2015 | 12:39 PM
  #59
saeki1's Avatar
2013 S550
Call the dealer, give them your vin, and ask if your car has ABC or Airmatic suspension.
Airmatic comes with 3 rods and ABC comes with 4. One he posted here is for Airmatic(without ABC suspension).
Old Jul 8, 2015 | 12:51 PM
  #60
1bad540's Avatar
mines airmatic.
Old Jul 8, 2015 | 01:47 PM
  #61
WHPH28's Avatar
This is correct.
Old Jul 9, 2015 | 05:43 PM
  #62
1bad540's Avatar
Ok so I can order the ones you posted a link for? those should work on my car right? are those generally the ones to go with?
Old Jul 9, 2015 | 05:48 PM
  #63
WHPH28's Avatar
Correct, if you have airmatic and not ABS the ones posted are the ones to get.
These, Ghostlinks, etc. There are many manufacturers and prices vary by 1 or 200.00. If you pop off one of your oem links you will see how cheap it is....lighter than a pencil. If I was a good machinist I would just make them because it can't cost much to produce them vs the price they are sold for.
Old Jul 9, 2015 | 05:54 PM
  #64
WHPH28's Avatar
Here are the ghost links that people on here have went with also for airmatic:
http://www.ghostmotorsports.com/ghos...-airmatic.html
Old Jul 12, 2015 | 09:16 AM
  #65
1bad540's Avatar
Looks like the ones you got are pretty good quality? would you get those again?
Old Jul 12, 2015 | 05:18 PM
  #66
WHPH28's Avatar
Yup, I would definitely buy them again.
Old Jul 12, 2015 | 09:17 PM
  #67
Bamzilla's Avatar
2013 S550 - Diamond White
Am I following this right? All you need to lower an S550 with Airmatic is a new set of links!?
Old Jul 13, 2015 | 08:36 AM
  #68
WHPH28's Avatar
That is correct and about 2-30 minutes of your time.
Old Jul 13, 2015 | 05:26 PM
  #69
Bamzilla's Avatar
Holy crap! This is a monumental revelation coming from the world of spring clamps and lowing springs.
Thanks for the info! You are the harbinger of rad news.
Old Jul 13, 2015 | 07:17 PM
  #70
WHPH28's Avatar
yeah....pretty simple to lower the w221.
