Oil filter housing
If you look in the third photo (bottom left) that little piece was inside the first photo in the middle of the hole I don't know if it's broken or what I need advise ??!!?
NO NO NO!!!
Your filter housing is missing the bottom third or so. The "shaft" should taper down to a point, and there are two or three rubber o-rings that are fitted to the (missing) tip. You'll need to order a replacement.
It appears the missing half is stuck in the metal housing (though it's hard to tell from the angle
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
yeah someone broke the center shaft that seals the filter. ouch man. you should be able to just pull that black thing in the housing right out. Its supposed to be part of the plastic piece
