W221 Clearing clogged windshield drain gutter
Old Dec 27, 2015 | 05:18 AM
KNBS550's Avatar
Mercedes-Benz 2007 S550, 2012 S550 4-Matic, 2014 S550 (Traded), 2015 GL450
We've had some heavy rains in my area recently and when I checked the drain holes at each corner, at the base of the front windshield, I noticed they were full of water. This made me panic a bit because I've read about water intrusion into the cabin from similar situations and causing electrical issues, especially with the W220 series vehicles.
At first I took a coat hanger, unwound the coiled portion around the hanger hook area and turned it into a long metal wire to stuff it into the drain holes to clear them. I had success on the PASSENGER side, but the DRIVER side still had water and wasn't draining. I tried to unclog it some more by jabbing the straightened wire coat hanger through the drain hole and after half a dozen attempts, still no luck. I poured in more water to see if it was draining at all and it was just sitting there. I even tried blowing into the drain to see if it would push the debris out and still nothing. Frustrated I gave up to sleep on it.
The next day, I go to Lowe's and ask for a small radius wire brush type tool that was flexible enough to go down curved pipes. The guy shows me this thing called a DRAIN WEASEL. It is a long plastic rod that has velcro like strands at one end to catch any debris. $6 later, I stuff the DRAIN WEASEL down the DRIVER side drain, pulled it out and voila...it caught a good chunk of compacted dirt that was stuck inside. I did this multiple times to make sure the drain was completely clear of any dirt or debris. I then flushed the drain with water. The water flowed unimpeded through a weep hole at the back of the fender liner, behind the wheel and to the ground.
I'm usually OCD about clearing leaves and pine needles from the windsheld and the car is parked in a garage so I was a little surprised to have the drain plugged as much as it was. Anyway, just thought I'd share this with the forum in case you had similar issues.
Old Dec 27, 2015 | 11:48 AM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
KNB...thanks for the info.
Hd
Old Dec 28, 2015 | 12:42 PM
KNBS550's Avatar
Hd
No problem, you're welcome!
BTW, I didn't mention in the post that the drain weasel has a handle at one end to rotate the brush at the other end. The whole thing is flexible enough to bend around gradual corners and the 'brush' rotate as it collects dirt and debris.
Old Dec 28, 2015 | 01:43 PM
1625guesswho's Avatar
2010 S 400 Hybrid
Thumbs up THANKYOU!
I just did this last week but this device you got seems to be an awesome alternative to me also using the wire hanger. Thanks man!
Old Jan 8, 2016 | 02:50 AM
S550v's Avatar
S550 4MATIC
Great post KNBS550. Alternatively, you can also use Fish tape, an approx 3 to 4 foot long portion is good enough. I taped off the sharp end of the fish tape with electrical tape so it doesn't scratch the plastic tubing inside. The fish tape is very strong steel, yet flexible enough to maneuver through turns and clear up clogs. I do like the flex/handle of the weasel. Here in Vancouver BC, I couldn't find a similar item at the retail level.
One added tip for you who are cleaning out your drain pipes... is to also (partially) remove the fender liner (just a couple of plastic clips), once exposed, due to the debris clogging the weep hole you will notice large amounts of debris/sediment at the base of the weep hole, at the bottom of the fender lining and also inside where the side skirt resides (there is a small corridor/gap that runs perpendicular to the skirt). I was amazed at how much debris accumulated in there overtime. So removing it is a good ideal esp if you live in damp climates like I do and if you park outdoors daily like me. I clean out the pipes twice a year now.
Note, there is also a 3rd drain pipe that drains water from the hood.
Old Jan 8, 2016 | 02:51 AM
S550v's Avatar
S550 4MATIC
sorry double post..
Last edited by S550v; Jan 8, 2016 at 02:55 AM. Reason: removing text due to double post.
Old Apr 9, 2018 | 11:18 AM
StayClassy's Avatar
N/a
Sorry I know this is an old post but I ran into this issue today. I have 2011 s550 and noticed the passenger side floor a little wet right below the blower. First thing I did was I looked in the container under the hood on the left side next to the battery there was water standing which I think should be empty. Also the drainage you guys are talking about is on the left and right side they are tubes going down ?
Old Apr 9, 2018 | 11:46 AM
konigstiger's Avatar
'71 Pinto
File Type: pdf
Old Apr 9, 2018 | 11:52 AM
StayClassy's Avatar
N/a
Great thank you for the replay it seems I need to clean out items 90 and 100 they might be clogged. If those are clogged would they allow water back into the cabin foot area ?
Old Apr 9, 2018 | 11:57 AM
'71 Pinto
Yes. In addition, check if sunroof drains (front/rear corners) drain properly.
Old Apr 9, 2018 | 12:00 PM
StayClassy's Avatar
N/a
Will do! I appreciate it.
Old Apr 9, 2018 | 01:23 PM
S550v's Avatar
S550 4MATIC
For unclogging drains (part 90 & 100)
Hi,
Just a tip for unclogging the two side drains (90 & 100) . Use a 5-6 ft fish tape rod. (Used for pulling wire through conduits, behind walls etc). I snipped off 5' of it and keep it for this purpose. Taped one end with electrical tape (to round off sharp edges and to protect the internals of the plastic drain pipe). Insert fishtape into drain (pushing up and down) and you'll notice the water will clear out from the front wheel well (behind the front tire). Theres a small cutout where water drains out. I went an extra step and also removed the rear portion of the wheel well to gain access behind the pipe and physically remove the debris blocking the pipe. I found a ton of leaves and buildup over time.
I've got a 2009 S550v (presume its the same for MY 2010-2013) and have noticed especially on the passenger side ( part # 100) the plastic black molding on the bottom runs the length of the windshield directing water to the pipe (100 & 90). But I have noticed the water doesnt actually flow 100% of the water into drain 100. So, i cut out a lip (using a plastic water bottle) to funnel/direct 100% of the water down the pipe. Easier to show if I attached a photo.
This wouldn't be a problem for us S-class owners if Mercedes had used a finer grid mesh, so larger debris cannot flow into the two drain pipes (part 100 & 90).
By the way, my dealer wanted to REPLACE the drain pipes (parts and labour over $600) cause they said it cannot be unclogged. Only replaced. I call that BS.
Cheers
Old Apr 9, 2018 | 04:28 PM
StayClassy's Avatar
N/a
thanks for the details I will definitely be doing that this afternoon,
Old Apr 9, 2018 | 04:33 PM
S550v's Avatar
S550 4MATIC
Good luck! And use a fish tape cause its strong & flexible enough to push through the drain pipe.
Old Apr 10, 2018 | 08:24 AM
1bad540's Avatar
s550 Diamond white amg pano
I used to clean out mine every few weeks, like others have said a fine wire up and down is enough to keep them flowing if there not stuck already. I had water intrusion in the car when i had 1st got it....pain in the a$$.
Old Apr 4, 2020 | 12:42 PM
s550hollywood's Avatar
2013 s550
What if I just removed 100, 110, 120, 140 and 90 of the diagram on my w221 and just let the water drain freely wherever it wants?
Old Apr 4, 2020 | 03:41 PM
'71 Pinto
IMHO would not recommend this.
Old Apr 7, 2020 | 06:28 PM
2013 s550
I found a pocket molded on the rear side of the fender wells which #90 and #100 flow into. This pocket was full of crap which was not allowing water to escape through the small hole on face of fender. I took this picture behind the front driver side fender well I pulled back after removing two push pins at bottom of fender. The pocket that 90 and 100 drains into is the problem, as it acts like a bowl at the end of a straw. It would be like you putting a hole in the bottom of a bowl and then funneling water into the bowl with a straw, leaves and dirt flows into the bowl, eventually the hole in bottom of bowl gets clogged up and acts like a damn. My suggestion is to take the end of 90 and 100 out of the pocket (bowl) and place a piece of clear water hose onto the end of 90 and 100. Extend this piece of hose beneath the car. This way you remove the damn all together and when you run your fish tape or weasel through 90 and 100, you'll be pushing any debris and leaves out the end of the clear tubing you extended beneath the car. Mercedes should of did it this way. They did that with 140 and 110 as when you pour water in those, it comes out two tubes beneath the car.
Old May 9, 2020 | 12:19 PM
W221CDI's Avatar
W221
Anyone used Karcher pressure washer from the top ? Just wondering if I can blow everything out this way?
Old May 9, 2020 | 01:04 PM
2013 s550
That won't do anything because the drain tubes #90 and #100 on the spec sheet above lead to a small pocket on backside of the front fender wells which only has a small hole which you can see behind the front tires. Nothing larger than that hole is going to come out no matter what you do. I created a fix for this in this video, once you complete this fix on your W221, you can then use different methods of cleaning out the tubes and everything you push down the drain tube will end up going into a 1 1/4 inch diameter hose and fall out underneath the car, see how I did it in this video:
Here's an image of my fix:
Last edited by s550hollywood; May 9, 2020 at 01:13 PM. Reason: added some pictures
Old May 9, 2020 | 02:46 PM
W221CDI's Avatar
W221
I just used pressure washer located on petrol station to see what’s happens. I put it deep as I could inside and.. go! I could not believe how much black crap comes out through wheel arches on both sides.. I also checked and drilled a slightly bigger holes in wheel arches to make sure nothing gets stock in there in the future. I think it’s best way to do it by pressure washer as manually you won’t clean it as good by just pouring the water. I’m happy with the results ! 😁
Old Nov 13, 2020 | 05:14 PM
2013 s550
I discovered that using an air compressor blow gun, and blow from the bottom of the cowl drains upward will clear them of any debris that may be clogging them. Blowing from the top doesn't work because the drain tube gets narrow as it goes downward. I also made small leaf catchers to prevent leaves and other small tree debris from entering the cowl drains. These three videos will explain what I did.
Part 1 of 3
Part 2 of 3
Part 3 of 3
Old Jan 30, 2025 | 08:11 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
I replaced my cowl, part 20 in the diagram above. As I buttoned everything back up and checked for leaks, I'm concerned about how part 90 and 100 drain. There is a needless gap between the bottom of the cowl and the drainage tube going to the ground. Upon close inspection during testing, I see some water missing the drainage tubes, and thus spilling where it shouldn't. Does anyone have a solution to correct this poor design? And does it matter if some water spills out around the collection point? I'm unsure if water from this area would ingress into the cabin, as that wouldn't obviously be bad. Or maybe it was always like this and I'm just noticing now due to paying close attention?
Old Jan 30, 2025 | 08:18 AM
BOTUS's Avatar
S500
Originally Posted by s550hollywood
this mesh add-on is exactly what the incompetent morons at Mercedes never understood it needs
a jet wash will work just fine too - the rainforest the entire length of the pathetic tube comes out just fine - but you and the car will need a wash afterwards
you can ram a cheap bottle cleaner brush in there and compact the rain forest and evolving life forms if you like - but jet wash - bottle cleaner - then another jet wash method works even better
Old Jan 30, 2025 | 09:11 AM
nath_h's Avatar
It isn't a clog...I cleaned that out previously. It is that there is a physical gap in space between the water baffle and the drainage tube. Not all of the water makes it into the drainage tube. I'm wondering if anyone has figured out a way to close the gap and ensure water gets channeled out. It looks like the waterfall would dump it all in the tube collection point, but there is some that splashes out the backside.
