View Poll Results: Guess cost of new battery for 2010-2013 s550?
200
4
8.70%
300
14
30.43%
400
28
60.87%
Voters: 46. You may not vote on this poll
Guess how much dealer wants for a new battery (2010-2013 S550)
Old Jan 7, 2016 | 10:12 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Take a guess.
Old Jan 7, 2016 | 12:27 PM
Mike5215's Avatar
2016 C300
I want to say pushing $400. It is a huge battery with a lot of cranking amps. Since it combined the accessory battery and the starter battery in one it's not cheap.
Old Jan 7, 2016 | 03:01 PM
DaveW68's Avatar
Veteran: Army
2015 S550
You can buy a matching AGM battery at many auto-parts stores for under $150.
Old Jan 7, 2016 | 03:05 PM
Jason B's Avatar
$414. I just thought was was insane for a battery. I wouldn't buy from the dealer anyway, but damn.
Old Jan 7, 2016 | 03:22 PM
Jason B's Avatar
Ok, Sam's club has it. When I called them before I posted, they said they didn't, but they do. Two choices. Again, this is for 2010-2013 S550 with ONE battery up front, both 3 year free replacement:
http://www.samsclub.com/sams/duracel...prod3590267.ip
$119
Specifications
Battery Electrolyte Composition:Acid
Battery End Type:Top Post
Battery Purpose:Starting Lighting Instrumentation
BCI Group Size:49
CA at 32 degrees F:1105
CCA at 0 degrees F:900
DIN code:H8/L5
Freight Class:65
Polarity:Right Positive
Reserve Capacity:185
Terminal TypeIN/SAE
Volts:12
OR
http://www.samsclub.com/sams/auto-gr...uestid=4375412
$169
Specifications
20 amp hour rate:92
Battery Electrolyte Composition:Glass Mat
BCI Group Size:49
CA at 32 degrees F:975
CCA at 0 degrees F:850
DIN code:H8/L5
Freight Class:65
Reserve Capacity:170
Terminal TypeIN
Volts:12
Old Jan 7, 2016 | 03:40 PM
Mike5215's Avatar
2016 C300
Mine had some prorated warranty left on it. Forget what I paid but it wasn't close to full boat.
Old Jan 7, 2016 | 05:04 PM
T.H.Carrera's Avatar
2012 w221
i thought i saw the oem battery for $200 on one of the oem parts distributor sites recently.
Here it is :
http://www.mboemparts.com/oe-mercedes-benz/0055411001
Old Jan 7, 2016 | 05:13 PM
vantage78's Avatar
2005 SL500
I recently had my battery replaced gratis under warranty. For those that are still under warranty, try that avenue first. $400+ is one expensive OEM battery!!
Old Jan 7, 2016 | 05:16 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Here it is :
That battery drawing looks like it was done by my 10 year old son.
Old Jan 7, 2016 | 05:21 PM
Mike5215's Avatar
2016 C300
At first I didn't realize it was a drawing at all. I thought it was a photograph. The level of detail is astonishing. I felt like I could reach into my monitor and touch it. Breathtaking.
Old Jan 7, 2016 | 06:40 PM
fastlife23's Avatar
Cl 65
lmao @ the drawing
Old Jan 8, 2016 | 02:08 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Bought mine at Autozone $158 with 5 yr warranty. I like Autozone, they have replaced batteries in my other cars with no hesitation. Once while in Oklahoma on business.
Hd
Old Jan 8, 2016 | 03:22 PM
Jason B's Avatar
Was it a AGM battery? Remember, the factory battery is an AGM, which is much more robust than standard acid.
Old Jan 8, 2016 | 04:50 PM
natcahd's Avatar
Veteran: Air Force
Jason...All of the numbers look very close. If it becomes a problem i will definitely get it replaced. It was the local managers suggestion. Price difference was minimal.
Hd
Old Jan 10, 2016 | 11:47 AM
bha's Avatar
bha
13 GL350, 14 SL550
Factory battery is an AGM and it's recommended over an acid battery.
$169 is a good price for what is basically the identical battery to what the dealer sells. There aren't a lot of battery manufacturers, so if it isn't a very very close copy it may actually be the same thing re-labelled.
I'd drop the $169 in a heartbeat and put that battery in. If you're trying to save $ an acid battery works just fine too.
I went and bought an Everstart Maxx H8 at Walmart (Canada) for I think $125Cdn. That was THREE years ago for a diesel GL and it is about to go into it's 4th winter (and almost 100,000km or 60,000 miles) since replacement. I'll probably replace it in the spring just because I don't believe it will last 7 yrs like the original. Probably a waste to replace it but for $125 for the next 4 years of worry free driving it's worth it.
It is an acid battery (probably the same battery as the $119 Sam's club one).
Works just like the original and I'm really happy with it. It is in the passenger compartment to (under passenger seat) so if an acid battery is OK there, it's definitely OK under the hood of an S-class. Had the same vent tubing holes/configuration so the vent tubes plugged right in.
Old Nov 4, 2016 | 04:09 PM
Jason B's Avatar
$169
Specifications
20 amp hour rate:92
BCI Group Size:49
DIN code:H8/L5
Freight Class:65
Terminal TypeIN
Volts:12
Got this one put in today. Original battery was starting to crank weak, and this battery is an AGM and same as factory specs, or more. Factory battery got decent life I'd say.
Old Nov 5, 2016 | 12:52 AM
$100 GUY's Avatar
C207
Around here it was around $650.
And yeah, I agree, OEM MB batteries are pretty good. I like how they last.
Old Nov 5, 2016 | 06:01 PM
GPrime2's Avatar
2007 Mercedes S600
But Dave those don't have Mercedes logos on them. I mean come on that adds at least twice to three times the price.
Old Nov 5, 2016 | 11:02 PM
1bad540's Avatar
s550 Diamond white amg pano
does the car need to be programmed after a battery swap like the 7 series do?
Old Nov 6, 2016 | 09:25 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Nope. On the pre face-lift cars, the electrical components will hold a charge from the starter battery. On the 2010+ cars, the components will hold a charge from the small battery under the dash while the old battery is being swapped.
Old Nov 7, 2016 | 07:21 AM
1bad540's Avatar
and the adaptations dont need to be reprogrammed? I hope this is the case... On the 7 series dealer battery from dealer is 7-900.
Old Nov 7, 2016 | 12:26 PM
DaveW68's Avatar
Veteran: Army
2015 S550
No programming needed. You keep all of your radio presets, seat memory, etc. Just replace and go.
Old Nov 10, 2016 | 09:42 AM
Jason B's Avatar
thats pretty cool. I didn't know that about 2010. Is that small battery just for that purpose? Any pic of this thing for fun?
Old Nov 10, 2016 | 10:24 AM
DaveW68's Avatar
Veteran: Army
2015 S550
I don't think that is the only purpose of the under-dash battery. I have a pre face-lift car, so I don't have a pic of that battery. But I'm sure a search of the forum will yield you some pics.
Old Nov 10, 2016 | 10:29 AM
DaveW68's Avatar
Veteran: Army
2015 S550
This H8 AGM is the exact same battery used as the accessory battery in the pre face-lift cars. I like the idea of having a separate starter battery. My original accessory battery lasted 10 years, while the original starter battery got 9 years of use.
