Adding Sirius, car is not prewired
Hello,
I have a 2007 S550 and want to add Sirius. I have a copy of DAS.
The car is NOT prewired for Sirius, but I think I can still add it.. here's why:
I have procured a Sirius (SDARS) module and it has the following connections:
1. Fiber (one fiber in, one fiber out)
2. 4 pin connector (+12v, ground, "wake up" and something else, can't remember)
3. Antenna connector
For #3, I'm using a Sirius "puck" style antenna (which I will put on the back deck). Have done this before on a W220 and it worked fine.
#1 and #2 are in the same connector. For #1, I assume I need a piece of fiber, and can add this device to the loop (pull fiber out of another module such as voice control, plug into SDARS, then take new piece to connect SDARS back to the voice control)
Wiring seems pretty simple.. +12V and ground. Wake up (I think) needs +12V to turn the SDARS on, so I'll just use the same wire to connect to +12V and Wakeup, therefore keeping the unit alive all the time.
Anyone know what the 4th wire is for? I assume is serves a purpose but can't figure it out.
Then I'll code the unit in using DAS.
There are other cars that use the same SDARS so I assume it's pretty similar. My SDARS came from a W204 but I believe W219 and a few other models use the identical unit. There are different revisions of the unit (some have "HD" radio, etc.) but they seem pretty interchangeable between models.
Will this work?
Will this work?
I guarantee you already know more about this than any of us. For me at least, the compression on Sirius/XM's music streams render them unlistenable, but I understand there are a lot of talk, sports and news streams too.
I would say if your car has an IPod integration unit (not many 07's did), get a BlueTooth adapter and the Sirius/XM app on your smartphone.
On your question. If you have the optical in/ out, antenna and power I wouldn't worry about the 4th wire.
Yeah. Surprisingly, beaming audio to geosynchronous satellites and then trying to beam it back to earth to thousands of tiny receivers turned out not to be the most effective way to stream music.
I get a 'no service' message when trying to use Sirius. Occasionally the radio works but not for long. I have a free introductory service and have had signal sent several times. Always the same result. Anyone have the same issue. Car is a 2010 s550
Location: Land of Political Criminals and Urban Shootings
2015 S550
I have not had to pay for Sirius radio in my S600 or my previous M5. I had the M5 about 18 months and have had the 600 about 14 months. Did Sirius offer lifetime subscriptions at some point?
Personally, I don't think the Sirius music channels sound bad at all. To my apparently unrefined ears, they sound almost identical to CD's. My biggest beef is that they have that Cousin Brucie clown on 60's on 6 who just never shuts the f#ck up. Sirius music is supposed to be commercial, and for the most part talk free. The sports channels sound the worst as they sound like the announcers are talking into cans.
In any event, I agree with Mike - Sirius is not a great listening experience. Also, not sure what OP's set up would result in but my '08 does not get all Sirius channels. The receive is not, uh, receptive to them. A known issue. Which leaves theSirius choices pretty sheite, none of my fave channels are available.
I advise OP make sure how many channels he's gonna get before going through with all of this.
Or just hook up the Bluetooth somehow and do that.
XM and Sirius were launched as separate competing subscription commercial free digital radio services. The economics were wrong and they each ended up adding commercials to their most popular channels, and adding more content.
Since there is a fixed amount of bandwidth on the satellites, they had to allocate it to the music channels based on revenue. (The talk and news channels used very little to begin with.) So the commercial laden, most popular channels got the most and sounded a bit better, where the more obscure ones got squat.
XM and Sirius eventually merged and I'm amazed they're still in business, since so many ways exist now to stream music in relatively high quality commercial free, but if you like the news/sports/ talk programming it's still the best option for that stuff.
