1. Car Forklifted Onto Delivery Truck Because Auction Had No Key
2. Finally Sees Car and Damage In Person on Delivery Truck
3. Videos of S-Class Forklifted Off Delivery Truck And Slid Into Garage
4. Additional Rear-End Damage Photos
5. Cost Breakdown For Vehicle and Parts as of 3/12/16
6. Key Arrives! First Start Up.
7. First Test Drive, Warning Lights Abound
8. Fixed Electrical Issues(?), Replaced Battery and Alternator
9. New Woodgrain Steering Wheel Installed
I finally bought it Fellas!
Heres a video of what I'm talking about. Maybe someone knows the way to erase codes?
Sorry its sideways.
I think the only option is to erase them all.
I wonder if I have to go to the dealer to erase the codes? I called the shop the MB Indy which is giving me the estimate today and they said they only do collision, no scans.
When I track down a misfire, I always move the coils to another plug and see if the misfire follows. If not, the coils are fine. I then move the indicated misfiring plugs to another location and see if the misfire follows. If not the plugs are fine too.
A little detective work keeps parts cost and frustration low.
"What do you think is wrong with me doctor? I can't breathe!"
"Hmmm. Let me try putting a cast on your leg!"
"There's nothing wrong with my leg!"
"Right. Let me check your prostate!"
"What?! I can't breathe!"
"I'm thinking about getting a small refrigerator for my office!"
"Holy crap! I'm dying Isn't there some kind of test or something you can run."
"Tests are for suckers! Lets try a hysterectomy!"
Coil boots are soft and rubbery with no tears. #1 & #2.
Coil boot #5 and #6, same as above.
The plugs look in good condition. They are NGK R(with Mercedes Symbols) so he had the car serviced. Is it not that the stock plugs are bosch? If so then he had the service done at MB.
Its not fuel because it would be a grayish color due to those cylinders running lean.
Not injectors, not plugs, not coil boots. So it must be coils. Can someone give me guidance please?
Once cleared run the car and see if the codes come back. If they do, move the coils to another cylinder that does not show a misfire. Then clear the codes again and run the car.
http://pages.ebay.com/motors/link/?n...314194&alt=web
Seems like this may be a good investment for you Benzs?
Ohming wires? What wires? Its a coil on plug arrangement.
there is so much bad info in this thread its painful.
