Retrofit Heated Steeering Wheel?
"The only thing that felt like a tacked-on afterthought was the optional heated steering wheel. Mercedes puts a wooden steering wheel in the S-Class, but if you get it, only the two leather swatches on the outside of the wheel will heat up. To warm your digits, you’ve got to keep your hands on the leather at exactly 3 and 9 o’clock – a position that I don’t find comfortable."
Thought I'd add something funny. Still, even in the 14-17 S class, only the leather portion of the wheel is heated if you get the optional heated wheel. In that car it's every worse, as the only portion that is heated is the bottom leather only, which you never grab. Some quotes from w222 forum.
Interesting. Is this the 2010+ style wood wheel? It has wood too?
If I remember, the heated wheel for the w221 can't be had in wood, or the wood part wouldn't be HEATED.
That's not good.
Did You manage to do the swap?
I am in the middle of same retorfitting fro my CL216.
When I look the original EPC for my C216, it shows me:
1) Install a heated steering wheel A221 .... This is logical.
2) Install the steering column switch with steering heater switch A1645403145 Again, very logical.
3) Install new steering column clock spring A1714641018. (replacement part number, older part number A1714640618) That purpose I can't understand!
They look absolutely indentical, clock spring with/without heataed steering. I can undestand that the power consumption is higher, probabaly more powerful wiring inside.
4) And now the tricky part - To install new rear SAM A 2215452916. Basically impossible to find. You mentioned, that You have Night-vision and by that this retrofit should be easier.
My car also have N/V, but EPC still shows the need for change.
I would preciate if You can share Your experience!
Didi You manage to do the retrofit without swapping SAM?
With greetings from Estonia,
