squeaking brakes
If yours are replaced and squeal that means they are not bedded correctly. The initial transfer of pad material to rotor never happened. This is common. Do the following:
Brake a few times casually to get rotors warmed up.
Perform three threshold (no abs) brakes from 30 to 15mph
Perform three threshold brakes from 45- 50 to 15 mph
Perform three threshold brakes from 65 to 15 mph
Drive for 10 minutes (ideally longer)
All of the above should be done without coming to a stop. Very important.
Drive for 10-15 minutes to let the rotors cool off.
Again- do not come to a stop at any point in the above exercise.
If this does not result in quiet brakes your caliper springs need to be tightened. Somebody rough handled them during removal or installation.
I personally prefer ceramic brake pads on my cars. They produce significantly less dust and have a much lower chance of squealing.
The catch is that if you are taking your car to the dealer for a brake job they WILL use MB OEM pads. If you want ceramics you might be able to talk your SA into it but I doubt it. However, an indy will do what you ask... or else you just DIY your brakes.
I buy most of my parts from Rock Auto. They only have 1 manufacturer for ceramic pads listed which is Akebono. I've seen several other folks on these forums mention them. There might be other manufacturers out there but I haven't come across them.
For more info on the differences between semi-metallic and ceramic pads check out http://www.autoanything.com/brakes/t...-metallic.aspx
