Coolant Leak
Old Nov 25, 2016 | 05:52 PM
604benz's Avatar
2015 S550V
Coolant Leak
Hi Guys
I am losing a little coolant every few weeks I get the low coolant message, I see on the drivers side where the rad pipe is connected is wet, could the clamp be loose or are these rads known to leak from this area.
Any info appreciated
Old Nov 28, 2016 | 10:25 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
IIRC there is a ring inside that shrinks over time and allows leaking. The rings should be fine but wouldn't hurt to replace if you can find it. I am having this same issue.
Old Nov 28, 2016 | 01:09 PM
604benz's Avatar
2015 S550V
Mine looks like its leaking from where the air intake pipe is attached to the rad, there a hairline crack and coolant is dropping onto the pipe, I'm going to try some JB Weld.
Has anyone heard of Benco brand of radiators.
