Headrest won't go up/down
Old Nov 27, 2016 | 11:23 PM
kbre1033's Avatar
07 S600 (W221)
MBWorld
I have a 07 S600 and when hitting the button on the command center to lower the rear headrest, they won't lower. I do have dynamic seating where the headrest should raise when I fasten the seat-belt, that doesn't work either, however, I'm able to raise/lower the headrest manually from the controls on the door. I've done some research that mentions it could be a fuse but I'm not sure how/where to check for this fuse and what other things I can try before taking it in for what I assume will be a hefty priced repair. Any guidance/assistance with this issue is greatly appreciate; Let me know if there's anything you need to help in resolving this issue.
Old Nov 28, 2016 | 01:41 PM
kbre1033's Avatar
07 S600 (W221)
Thanks Plutoe
WDDNG76X57A107098
Have you seen this error before; is there a DIY option to resolve this issue?
Old Nov 28, 2016 | 02:31 PM
konigstiger's Avatar
'71 Pinto
You can check 143 at rear fuse panel if fine, long shot pull for several minutes in an attempt to reset. If this fails most common fix someone may need to reset using MB DAS (diagnostic system).
Attached Thumbnails Headrest won't go up/down-capture.jpg
File Type: pdf
Old Nov 28, 2016 | 03:20 PM
kbre1033's Avatar
07 S600 (W221)
Ok, maybe I'm still recovering from Thanksgiving drinking but how do you access the fuse box in the rear? The instructions say simply 'pull' in direction of arrow but the access hatch doesn't budge. Will a screwdriver or another tool work without breaking this hatch?
Old Nov 28, 2016 | 03:57 PM
kbre1033's Avatar
07 S600 (W221)
Thanks konigstiger, I was able to 'finally' open up the rear fuse compartment, checked the fuses and they look good.
Old Nov 29, 2016 | 10:40 AM
'71 Pinto
Rear SAM: http://workshop-manuals.com/mercedes...on/page_11235/ + next pages, also see attachment.
Since fuse seems fine and pulling doesn’t help, best bet is to have someone check it with MB DAS again, may be as simple as reset.
