Updating B&O System...?
Old 02-24-2017, 03:43 PM
compaddict's Avatar
2016 S63, 2013 SL63
My car is in the shop getting a single 6.5" Sundown in a small box with a Sundown amp.
900.00 installed. Will let you know if it does the trick.
Vince
Old 02-24-2017, 05:52 PM
Mike5215's Avatar
2016 C300
Originally Posted by Jason B
Now i'm wondering if the standard HK throws more bass than the B&O. It's possible it does.
Looking at the speaker arrays, the HK gets two 8" subwoofers in the front doors, plus the 8x12 on the rear deck ported to the trunk. These are very stout dual coil subs that can handle a lot of power. (They don't get a lot of power in the factory set up, but they performed great in the aftermarket set up).
The BO gets conventional 6" single coil woofers in all four doors, and the subs on the rear deck are 8", don't appear to be dual coiled and the module appears to be sealed (not ported to the trunk). In a car the size of a 221 that seems like it would have underwhelming bass.
Old 02-25-2017, 10:11 AM
compaddict's Avatar
2016 S63, 2013 SL63
Boom! There it is!
Smallish Birch vented box with 6.5":
http://www.sundownaudio.com/index.ph...x-rev-2-series
Sundown amp:
http://www.sundownaudio.com/index.ph.../sae-1000d-v-2
A breakout box and a knob for under the dash.
It sounds very good and it might be a little extreme but for 900.00 and no permanent damage to my car.. I could not be more happy.
Someone could duplicate this system at a small fraction of the money and get thirty percent of the sound that I have and be totally happy with it.
Pictures later!
Vince
Old 02-25-2017, 03:32 PM
compaddict's Avatar
2016 S63, 2013 SL63
Old 02-25-2017, 04:03 PM
1975benz's Avatar
2011 mercedes w221 s class
I went a little bigger with a 15" sub
2k RMS of added bass
Old 02-25-2017, 04:07 PM
1975benz's Avatar
upfront controller to turn bass up and down
Old 02-25-2017, 04:26 PM
  #32
compaddict's Avatar
2016 S63, 2013 SL63
Such a simple solution to a problem! I would have never believed I could be happy with a box in the trunk without porting into the cabin. My knob is way under the dash. Turned all the way down it adds a little something. Halfway up is just to impress the kiddies.
Old 02-25-2017, 04:49 PM
  #33
1975benz's Avatar
Im affraid im on the other end of the scale, I didnt want to tear my car apart or have to add more batteries split chargers and 0AWG cables all over the place, but my system which is ported through the existing sub on back shelf is the most powerful without altering the cars electrical system and I love it but would not play it with the kids in the car!!
Old 02-25-2017, 05:05 PM
  #34
compaddict's Avatar
2016 S63, 2013 SL63
I get that for sure. Mine is very simple, it is a tiny 6.5" in a small box and the battery is right there anyway.. And the Class D amp is very efficient as well.
Vince
Old 02-25-2017, 05:47 PM
  #35
1975benz's Avatar
Vince
I changed my s class and didnt realise that in the newer model theres no battery in the trunk but i also have a class D amp very small but efficient in time you will want a bigger sub!! lol
Old 02-25-2017, 06:32 PM
  #36
compaddict's Avatar
2016 S63, 2013 SL63
That is the cycle isn't it!
Old 02-25-2017, 06:35 PM
  #37
1975benz's Avatar
yep!!
Old 02-25-2017, 06:47 PM
  #38
compaddict's Avatar
2016 S63, 2013 SL63
That happened at my house. Started off with one big REL sub, then a second. That lasted a while. Then my friend John Nolte of Nolte Audio made me a deal on two bass enclosures with four 10" SQ woofers each. Around 350 LBs each box! Crazy good bass. He wants to make a dual 18" using my basement as a box for sub bass. I said no.
I already have three 110v circuits to run my home system...
Old 02-25-2017, 06:51 PM
  #39
1975benz's Avatar
give it a couple of months and youll be upgrading lol
Old 02-25-2017, 10:20 PM
  #40
Mike5215's Avatar
2016 C300
Holy crap! Are you a member of KISS?
Old 02-26-2017, 12:01 AM
  #41
Chanomatic35's Avatar
2015 E63 AMG S
I use 2x JL audio TW5's. 10". They are speciallly made with small enclosures in mind. The W212 doesn't even require you to use a separate line driver either. A good audio amp with a 24db/oct cutoff will really scratch your bass head itch!
Old 02-26-2017, 02:59 PM
  #42
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Whats up with the chicken wire speaker cover. Just. No.
Old 02-26-2017, 03:18 PM
  #43
1975benz's Avatar
my wife loves to put things in my boot that has no place in there but can damage my sub plus they dont make grills for very large and powerful 15" subs and to top it off the thicker the grill and smaller the squares the more air movement is restricted which is always bad!! but i should have sprayed it black!!
Old 02-26-2017, 03:22 PM
  #44
superpop's Avatar
10 buxs on fleabay, order stat. And any grill will have no effect on sound unless it is solid.
Old 02-26-2017, 04:05 PM
  #45
Mike5215's Avatar
2016 C300
One time, very early in our relationship, my wife tried to put things in my boot. Sorry babe, that's Exit Only.
Old 02-26-2017, 04:26 PM
  #46
1975benz's Avatar
lol and whats worse is she has her own car and was driving but because her boot is full of s**t she wants to put her stuff in mine?
Old 02-26-2017, 04:42 PM
  #47
superpop's Avatar
Why didn't they set up the box to fire against the back seat. Can you flip it around?
Old 02-26-2017, 04:48 PM
  #48
1975benz's Avatar
It was installed that way because theres no port into the car that way the air comes through the hole the old stock sub was in on rear shelf its very effective plus youd never know how powerful it is util you turn it up!!
Old 02-26-2017, 05:15 PM
  #49
Mike5215's Avatar
2016 C300
Try sticking your stuff in her boot and see how she likes it! Start with something small and then once she gets used to it go bigger.
Old 02-26-2017, 05:19 PM
  #50
1975benz's Avatar
I tried but she promptly told me she had no space I should stop taking the **** and left lol
