friend wants me to lower his 07 s550 via das star, need inclination values
Old Jun 7, 2017 | 11:20 AM
06cls55amg's Avatar
06cls
Like the title says, my buddy wants me to lower his w221 its a 07 s550,
is it hte same procedure as a w211/w219? also what are the inclination values only info i found was for s65 with abc.
thanks
Old Jun 7, 2017 | 12:31 PM
alx's Avatar
alx
Look at range and pick middle. Experiment a bit. You will have limited success with the 550 as any meaningful drop is out of bounds and will not save. But do try.
Old Jun 7, 2017 | 12:37 PM
06cls55amg's Avatar
06cls
i think you are thinking of level signals, i need the inclination angle values that i need to input into das/star for both left/right front/rear 11th pic down from 1st post. looking for an inch if possible.
https://mbworld.org/forums/w211-amg/...ts-o-pics.html
Old Jun 12, 2017 | 01:04 AM
mcypert's Avatar
2007 S600, 911 & XJ8
I'm curious. Does your friend have ABC or Airmatic?
I've been looking at lowering/raising my 2007 S600 because of a tire issue and have been led to believe Airmatic is easy with STAR, but not so with ABC....
I'll be asking again once I get the new rear tires mounted, but would like to hear any thoughts on the issue...
Regards... Mark
Old Jun 12, 2017 | 08:38 AM
alx's Avatar
alx
This is not how it works. You lower manually your car to where you want it and try to save the configuration by adjusting the inclination values so the system accepts them. The inclanation values are the real world check for the system that the car is where the system "thinks" the car is level- wise.
ABC cars are harder to lower with star as the value ranges are narrower and car gets out of bounds quickly even with small drops. There are other ways to tricks the level system to accept lower values. No, I am not going to share them as this is potentially a safety issue.
Old Jun 30, 2017 | 01:23 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
One thing you could do is code the ABC control module to an S65AMG variant, which will give a firmer ride and also drop the car slightly when parked for a more aggressive appearance, if you are into that. Make sure you have an alignment done after any adjustments.
Old Jun 30, 2017 | 08:28 AM
Mike5215's Avatar
2016 C300
Links (inexpensive, very easy to install, kind of a pain to calibrate) or a LoPro module (none of those things) seems like the consensus on drops.
Check out Adjustable Air Ride or Ghostlinks
