AUX in The W221
Old Jul 24, 2017 | 01:12 PM
Valentin Yuksel's Avatar
S350 BlueTEC 4MATIC W221
AUX in The W221
Hi, i've recently bought a S350 and strangely i cannot find the aux port anywhere. I do have an aux audio setting in the COMAND, but there is no port! The only aux port i found was in the back theatre system but that is all.
Old Jul 24, 2017 | 02:20 PM
Mike5215's Avatar
2016 C300
That's probably all you'll get. Run an RCA to stereo 3.5mm cable to wherever your device will be. Or a Bluetooth receiver so you can stream BT audio. Most 07-09 didn't get Aux at all. The Miccus BluBridge works well. It'll need power from a USB charger in a 12v receptical. (There's a battery but to keep it powered without pulling it out to charge it it needs a source in the car.)
Old Jul 24, 2017 | 02:45 PM
1975benz's Avatar
2011 mercedes w221 s class
what year is your car?
normally the aux connector is in your glovebox but the cable may have been removed so have aggod look around in there!!
Old Jul 24, 2017 | 05:31 PM
2011.
Old Jul 24, 2017 | 06:31 PM
Mike5215's Avatar
2016 C300
Sorry. On the 2011 you need the MMI cable specific to the 221. It plugs into the glove box, upper right, into a rectangular receptacle that looks like a wide USB port.
The cable splits off into a male 30 pin IPod cable and an aux cable with a female 3.5mm aux jack. Most of us used a Tune2Air Bluetooth adapter that attaches to the iPod cable.
