2013 S550 4Matic MPG
Old Aug 1, 2017 | 01:43 PM
aharon98's Avatar
2009 S550 4Matic
Hey guys my MPG doesn't move from 11.6 at all. Tried resetting multiple times but comes back to 11.6 mpg. Sometimes it goes up .1 or .2 mpg but very shortly. Any advice?
Old Aug 1, 2017 | 08:29 PM
steveb9771's Avatar
2007 CL550
Do a check the old fashioned way. Fill your tank and note your odometer reading. Wait until you have less than half a tank, then fill up and calculate your MPG based on difference in odometer reading and the amount of fuel used. This will show if you have an electronics issue or a real problem with your engine.
Old Aug 1, 2017 | 11:03 PM
aharon98's Avatar
2009 S550 4Matic
Any other way to check? Not sure how much gas it's supposed to drink I get it's a V8 but seems like a lot.
Old Aug 4, 2017 | 10:21 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Wow! And I thought my S600 V12 bi-turbo was bad at 13.5 mpg in local driving. You might want to think about having the lead removed from your right foot. You should be averaging at least 16 in the city and over 22 on the highway.
Old Aug 5, 2017 | 12:24 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
That is by design. While many cars will reset to the instant MPG at the time it was reset, MB vehicles reset to a weighted average value for that particular vehicle. Why it chose 11.5 is unknown, but if the cluster has the wrong coding in it, it can cause an incorrect reading. My V12 resets to 13.x on a fresh reset. After driving on highway trips for a few miles and conservatively, it will go above 20.
