Distronic Plus question
Old Oct 9, 2017 | 12:19 PM
Hatzenbach's Avatar
2009 W221
Hi,
my 2nd post, still learning the car.
I think in the manual it says that Distronic Plus will slow down the car to a complete stop and then start taking off by itself as soon as the car in front of me moves again.
The slow down part works, but the car doesn't start moving on its own
Is there a setting I missed?
Old Oct 9, 2017 | 03:32 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Originally Posted by Hatzenbach
Hi,
It will actually start going by itself, but it takes far too long as the car in front of you has to be quite a bit ahead before your car will move. By then, the people behind you are honking and you have a bunch of people cutting in front of you. The best thing to do is give the car some gas to get it moving again. As long as you don't put your foot on the brake, D+ will stay engaged.
Old Oct 10, 2017 | 09:45 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
I find if the car stops for a few seconds it starts right back up immediately when the car in front of you moves.
Old Oct 10, 2017 | 05:08 PM
tode's Avatar
W214 E300e
Same here . .
Old Oct 10, 2017 | 05:21 PM
user 58362638's Avatar
While the distronic is active and the vehicle has come to a stop (i.e. at a light). If you want to reactivate it, either pull on the cruise control stalk, the resume function. Or as others have mentioned, pushed the gas pedal, either method works. Although, I prefer using the cruise control stalk.
Greg
Old Oct 27, 2017 | 08:35 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
If the vehicle in front resumes moving in about 3 seconds, no interaction is required. If not, you must tap the accelerator or pull the Cruise Control stalk toward you.
Old Oct 28, 2017 | 08:25 AM
maniekS500's Avatar
S500 4M L
Yes - it works in this way I am also unhappy that when I cruising using Distronic and want overtake car (e.g. slow lorry I am behind of) my eSSa accelerates very slowly until it is fully on the left side (no in the shadow of pre-car). Last months drove Volvo V40 and when only I turn left signal on it reduced gear and started to accelerate - very nice.
Old Nov 1, 2017 | 07:00 AM
M-a-x-G's Avatar
w211
PolarBaer got it right; this is how it works on my w221 2011 as well.
Old Nov 1, 2017 | 10:25 AM
Hatzenbach's Avatar
2009 W221
Thanks M-a-x-g and PolarBear, yes now it all makes sense
