--new s350 w221 owner.. few wheel questions--help is appreciated
Old Oct 10, 2017 | 07:12 PM
berti_00's Avatar
2016 Cls63s AMG
Just picked up a 13' s350 bluetec and new into the s world. I've been on e class c class mostly..
Will this wheel work.. I see the have some huge wheel wells for sure..
20x8.​5 et35
20x10.5 et45
EDIT** this is a 4Matic
Not sure about tire size either
Will lower with lowering links as well.
Old Oct 10, 2017 | 08:34 PM
alx's Avatar
alx
20x8.​5 et35
20x10.5 et45
There is no staggered fitment in this model year so you are on your own. But if I can offer you a piece of advice (I have the same car) - do not go 20s as ride will suffer and you will be bending rims. My car came with the amg package and about two months into it all wheels were bent and i went with 18” less aggressive setup. Haven’t looked back. Also lowering will result in less pressure in the airmatic which will result in premature shock failure. Some Mercedes shocks have no problem running lower/ less pressure but the 221 shocks are sensitive and will fail. The 350 is not a sports car and trying to improve its handling is just not rewarding. You have been warned
Old Oct 10, 2017 | 08:56 PM
berti_00's Avatar
2016 Cls63s AMG
what does that mean there is no staggered fitment on this model?
Old Oct 11, 2017 | 08:40 AM
alx's Avatar
alx
i believe there is no w221 diesel with different size wheels from the factory... thus i am not sure unless you -really- match the overall diameter of the tires front to back that the 4matic can tolerate any difference in sizes. it might have been a fluke, but the only overheated center diff i have seen on a w221 4matic was one that was driven on a spare tire for 100 miles at highway speeds...
Old Oct 11, 2017 | 08:51 AM
DaveW68's Avatar
Veteran: Army
2015 S550
I've been running 20's for 3 years and have never bent a wheel. In fact, the ride quality when I switch to my 18's for winter duty is almost indistinguishable from my summer 20's. Perhaps it's the ABC suspension keeping the ride compliant.
Old Oct 11, 2017 | 10:24 AM
alx's Avatar
alx
this absolutely. i run 20s with very low profile tires on my sl65 and i have not had ride issues... still i do bend wheels, but i think this is par for new england.
Old Oct 11, 2017 | 11:56 AM
berti_00's Avatar
2016 Cls63s AMG
so what kind of tires for 20" does one have to use for a 4matic to try and match the rotation
sorry for the questions, i've never owned a 4matic and never had this issue.
Old Oct 11, 2017 | 02:59 PM
DaveW68's Avatar
Veteran: Army
2015 S550
255/35/R20 if you're looking to stay square.
Old Oct 11, 2017 | 04:51 PM
berti_00's Avatar
2016 Cls63s AMG
has anyone done these wheels??? 20x9 et35 20x10.5 et35 (or whatever to make it flush as these are custom made offsets) 255/40/20
275/35/20
http://www.ebay.com/itm/20-MRR-VP3-Wheels-Set-For-Audi-S4-S5-S6-S8-20x9-0-Inch-Squared-Rims-Set-4-/382230325693?hash=item58feb3e9bd:g:mfUAAOSwLVZV30Z 2&vxp=mtr
since the ET is custom on these what would be a perfect flush offset and tires to go with this? in case i order these.
are these good for a 4 matic
Old Oct 13, 2017 | 09:54 AM
berti_00's Avatar
2016 Cls63s AMG
okay so what kind of wheels would you guys run on this set up so there is less than a 3% rolling diameter between the front and rear axles for the 4matic
WHEEL SIZE :20x9 (Front) / 20x10.5 (Rear)BOLT PATTERN :5x112OFFSET :+35 (Front) / +38 (Rear)HUB BORE :66.56mm
Old Oct 15, 2017 | 08:18 PM
slcbbrown's Avatar
S550
Big wheels make a difference
Changing from the std wheels to bigger wheels will make a noticeable difference in road noise and ride comfort. It will still ride pretty good, but more like an e class.
I can't speak to wheel damage on my s classes, but I had no problem recognizing a change in ride quality when I test drove s classes with the AMG wheels. I can say that I've had tire blowouts at highway speeds with my wife's e350 that has the AMG wheels. Have to say that when the right front tire on the e350 blew at 70mph, I almost couldn't tell I had a flat. The car stayed completely straight and stable.
Old Oct 16, 2017 | 07:58 AM
1bad540's Avatar
s550 Diamond white amg pano
Let me tell you about Mercedes pizza cutter wheels, they are designed so the edge of the rim goes thru the sidewall, I have had custom and upsized factory wheels on everything for the last 15 years and never had a blowout, my stock 19" amg wheels on my benz I got a blow out the 1st or 2nd month I owned the car and sure enough rim cut thru the sidewall. I removed those wheels and changed the design. currently running a 255-35-20 and 275-35-20 on 8.5 fr and 9.5 staggered rims w a 35mm offset and they sit nice and flush to the wheel well.
Old Oct 16, 2017 | 07:59 AM
1bad540's Avatar
That said the upgrade from the 19" to 20" I dont see any notable loss of comfort.
Old Oct 20, 2017 | 09:26 AM
berti_00's Avatar
2016 Cls63s AMG
hey hit me up when you get a chance about the links
