S600 Coil
Old Oct 12, 2017 | 03:02 PM
GPrime2's Avatar
2007 Mercedes S600
S600 Coil
Before I go dropping an obscene amount of money on a coil for my 600, anyone got a new left side coil laying around they want to sell cheap? Or any idea where I can get one for a reasonable price? Any help locating one would be appreciated, 1200 bucks is a bitter pill to swallow but I'll do it if I need to. Thanks!
Old Oct 12, 2017 | 05:41 PM
alx's Avatar
alx
if you can afford for the car to be down for a bit you can have your coil rebuild for a fraction of the cost.
also, parts.com will have a brand new oem coil for about $1000. part #2751500780
lastly if you are the diy kind you can get spare individual coils and replace only the problematic ones for about $50 per coil.
Old Oct 12, 2017 | 11:09 PM
GPrime2's Avatar
2007 Mercedes S600
Do you recommend anyone to rebuild it? I'm not amazing with solder but I'm passable, I'm considering popping the top off of the coil and having a look, it was misfiring 10 and 12.
Old Oct 13, 2017 | 07:06 AM
DRTYLNDY's Avatar
Hello
I would suggest Clark Rupp over at V12icpack.com. You can rent a rebuilt coil pack from him to make sure you don't just chase parts and if it is the problem you can buy it from him. Last week I also lost a coil pack on my S65 and withing just a few days had my car back to new with the help of Clark and I saved some cash!
Good luck
Johan
Old Oct 14, 2017 | 05:20 PM
GPrime2's Avatar
2007 Mercedes S600
Originally Posted by DRTYLNDY
Hello
Good luck
Johan
Do you remember how much he charged to rebuild it?
Old Oct 27, 2017 | 07:56 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Not sure how much you have looked into it, but there can be several causes for misfires, and it is not always the coil pack. The voltage transformer could also be the culprit. I would change the spark plugs first if you haven't already, and check for oil seeping from the valve cover gaskets down into the spark plug area.
Clark will take your coil pack as a core and sell you one his company rebuilt for a reasonable price (they know what they are doing) but he will not take one if it has been opened up FYI.
Old Oct 27, 2017 | 07:59 PM
Polar Bear's Avatar
Also, you must clear the ECU codes correctly to make the misfire go away. You need to have the key on "Run" (position 2) and clear the codes with whatever tool you are using, turn the ignition off for about 10 seconds and disconnect your scan tool to allow the ECU to go to sleep. Then turn the key back to the run position and use the scan tool to confirm they are cleared. Otherwise, the engine will continue to misfire.
