ignition coils
Old Dec 5, 2017 | 08:33 AM
beebsie's Avatar
2008 S550 4Matic and 2014 E350A Cabriolet
ignition coils
My mechanic says 1 of 8 coils is bad. Q: Should I replace only 1 or assuming the others will go bad, replace all 8?
Old Dec 5, 2017 | 10:28 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
they are relatively cheap to replace.. If you dont want to mess with it for a while or ever again, just replace them all. If you are lightly mechanically inclined, you can just do them 1 at a time as they may or may not fail.
Old Dec 6, 2017 | 11:36 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Agree. They are relatively inexpensive but the originals may last the life of your ownership and at $55 ea for OE's,(MB Direct) still a good chunk of change to use for other maintenance uses.
Good luck,
Bob
Old Dec 6, 2017 | 05:53 PM
WHPH28's Avatar
Depends on the weather
They are pretty easy to do. I would do them all at once and cross it off the list...preventative maintenance. In my S600 I had one go bad but I had to replace the entire side as each side is one single unit as opposed to individual coils like my S550 was.
