Heated Steering Wheel not working
Old Dec 26, 2017 | 04:41 PM
florinh's Avatar
2009 S550
Hi,
I have a 2009 S550 and my heated steering wheel is not working. When I rotate the dial, the power in the indicator light turns on but there is no heat to the steering wheel. I'm thinking it could be a fuse but I am having trouble locating which fuse to check. Does anyone know which fuse link to the heated steering wheel?
Old Dec 30, 2017 | 12:00 AM
mbdr's Avatar
Mercedes
it could be clock spring issue as well
Old Dec 30, 2017 | 10:32 AM
konigstiger's Avatar
'71 Pinto
You can check f49 @ front SAM (engine compartment). If indicator lamp turns on then goes out it could be a voltage problem. Attachments cover system function.
