Ballast, xenon control unit (passenger side) keeps blowing
Old Apr 6, 2018 | 10:46 AM
zackaie's Avatar
s350
I have 2012 S class w221. After a few days i have bought a car the passenger side xenon (D1S bulb) stopped working. I changed the xenon bulb, but nothing worked. Then i swapped the ballasts(put the original from driver 's side to passenger side) and it worked. So i have bought from ebay used but original ballast and i put it to the driver' s side. So i left the original (which i took from drivers side) on passenger side. After a few days the passenger side xenon stopped working again. i changed the bulb, but nothing worked again, so ballast blown again. Does someone know what keeps blowing the ballast? I even went to local guy who is dealing with led* , xenons e.t.c. He connected his own aftermarket universal ballast , but the bulb was only flicking. I am afraid if i buy another ballast it will be blown again. What is the solution? Please Help!connected his own aftermarket universal ballast , but the bulb was only flicking. I am afraid if i buy anothe
Old Jul 14, 2018 | 12:45 PM
sjayaram's Avatar
W221.171
Hi, I am currently having a similar problem on my face-lifted W221, did you manage to find and fix your problem?
Thx,
Sid.
Old Sep 10, 2018 | 06:24 AM
Tarek Fahmy's Avatar
W221 / W211 / W202
Guys, Please check if there's any water leakage.
I had the same . . . and I found a very small crack at the top of the headlight, I lost several ballast till I found it.
