S600 OIL SEPARATOR/PCV
Old May 3, 2018 | 12:59 PM
Jtsnyder's Avatar
S600
Question S600 OIL SEPARATOR/PCV
This is on my 2007 S600.
I've searched and searched and cannot find a DIY to replace this part. It is easy to get to, but one of the bolts is blocked by the black metal pipe that goes around the oil filter in this photo. I believe it is a coolant line. My question is, can I remove this without losing too much fluid? Is the system pressurized and will I cause problems by opening it up? The part I'm replacing is the black disc shaped oil separator to the right of the oil filter. It is leaking oil down the front of the engine. In addition, if anyone has done this procedure, what is behind the oil separator? Is there a cam seal or any other seal that I should order that may also be leaking? Thank you for any help
Old May 3, 2018 | 02:12 PM
lionsfan54's Avatar
Mercedes Benz S600
It's coolant and it won't be pressurized when cold. Wait for the car to cool off and then take it off. You'll spill some (don't let your dog out in the garage for a drink!).
Here's a few schematics showing it (it's #6)
Old May 3, 2018 | 03:04 PM
Jtsnyder's Avatar
S600
thank you very much! Is there a site or somewhere I am able to find diagrams like this and possibly repair instructions for future issues? Even if I have to pay for it?
Old May 3, 2018 | 03:08 PM
lionsfan54's Avatar
Mercedes Benz S600
I don't know if a site exactly like that, but I got it from here. I searched on "coolant hose" and then filtered on 2007 S600
https://www.oemercedesbenzparts.com/
This site seems promising too
https://workshop-manuals.com/mercede...er/page_19005/
Old May 3, 2018 | 03:44 PM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
I changed mine. With the car cold you will loose very little coolant. Its an easy job, 15 minutes tops.
